yes i know anothe mpfi swap question
Old Jan 31, 2007 | 04:32 PM
JJ's civic's Avatar
Default yes i know anothe mpfi swap question
my question si i'm thiniong of doing a mpfi swap but i'm also thinking of going odb1 (for furture swaps don't knwo where i'm going yet) my questions are. everything thing i've read about the mpfi swap is to use a 88-91 si stuff but that's odb 0 what parts can i use to convert to odb1 and where can i find info about it?
Old Jan 31, 2007 | 04:51 PM
dr_latino999's Avatar
Default Re: yes i know anothe mpfi swap question (JJ's civic)
The only difference in the actual MPFI swap if you're going to OBD-1 is the distributor, but it still follows the same instructions since you can reuse the injectors. So pretty much -
- Wire up for MPFI
- Add OBD-1 conversion
- Re-pin OBD-1 Distributor to accept an OBD-0 distributor plug, or Re-pin native harness to have a OBD-1 Distributor plug.
nyckid
Apr 23, 2015 08:52 AM
SikAuto
Dec 28, 2008 12:58 AM
wwcrxww
Sep 28, 2008 09:52 AM
mr. carpenter
May 24, 2004 01:38 PM
streetdreams420
Aug 17, 2003 11:54 AM
