Honda S2000 Honda S2000
Ground controls on stock shocks
Old Jan 31, 2007 | 04:25 PM
Tyson's Avatar
Default Ground controls on stock shocks
anyone here put ground controls on stock shocks?
i'd like to know what it took to install. and what came in the kit.
does it fit in the stock cups? or do you remove them and use some adapter ring?
honestly, im trying to see if i can use my GC kit from my crx. (i will be using custom springs anyway)
the guy answering the phone at gc is not being too helpful.
Old Feb 1, 2007 | 08:33 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Ground controls on stock shocks (Tyson)
Stock top hats fit, just measure out the OD of the springs.
Old Feb 1, 2007 | 09:33 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Ground controls on stock shocks (Mr. Projekt)
Hope you're planning on riding around with big breasted women. BOUNCE BOUNCE BOUNCE
Old Feb 1, 2007 | 09:58 AM
Tyson's Avatar
well my lazy *** finally got around to seeing how the fitment is with my sleeves on the spare set of stock shocks i have. theyre missing the perches (user swapped them for konis which need the spring cups)
and it comes out ALMOST perfect. it slides nearly exact, until about .5" left before it fully bottoms out. its close. i measured the OD in the last half inch to be just 2.10 and the ID of the sleeve is 2.05". which means i just need to either sand the OD of the shock down, or the ID of the sleeve. 50 mil difference isnt much. i might just ask my machinist to turn the sleeves on the lathe. i dont think it will be any issue cutting that little off.
Old Feb 1, 2007 | 11:45 AM
* B A N N E D *
Told you so.
Old Feb 1, 2007 | 12:49 PM
Tyson's Avatar
told me what jackass. you wouldnt help me a year ago when i asked if rear s2000 shocks would fit my crx!
EdWord
Dec 7, 2009 02:19 AM
thi3v3z
14
May 19, 2009 06:41 PM
vdub08
Suspension & Brakes
Feb 17, 2005 12:14 AM
stoopid215
Sep 19, 2002 08:30 AM
arete213
Oct 3, 2001 03:39 AM
