Might just trade my Civic???
1992 Civic LX Sedan....Either trade for a 2 door or hatch...or sell outright with wheels MAKE REASONABLE OFFER. My company is based out of Madison, WI so I travel that way every so often....so I can deliver to your doorstep depending on distance and price.
*Good*
Interior in excellent condition
All power options work fine
The motor is in perfect condition. Absolutly no problems period. It has 190psi compression across the board. It drives and shifts smooth! It's actually pretty fast for the little mods it has.
*New*
Hood
Air Filter
Fuel Filter
Intake Manifold Gasket
Valve Cover Gasket
Oil Pan Gasket
Distributor Cap and Rotor
Ignition Coil and Module
Spark Plugs and Wires
O2 Sensor
Battery
Starter
Shifter Bushings
Left and Right Axles
Front Brake Pads
Clutch
All Fluids Flushed
Regular Oil Changes
*Mods*
D16Z6 Intake Manifold
D16Z6 Transmission
Short Shifter
SS Cat-Back Exhaust System
Adjustable Coilover Springs
Si Front Strut Tower Bar
New inner and outer tie rods
New rear control arms
17" wheels
Full set of 90% tread tires (may or may not come with wheels and tires depending on price or depending on trade offered)
*Bad*
It has it's normal minor small dents and dings and needs paint (fading on top and trunk). Normal Honda Rust starting above the rear wheels, but, as you can see in the pics, not bad yet. Idle surges every so often about a 200-300 swing, not sure why yet because it doesn't do it all the time. But will try to fix before letting it go.
Modified by DaBeastWthn at 7:07 PM 2/2/2007
Modified by DaBeastWthn at 7:08 PM 2/2/2007
Modified by DaBeastWthn at 7:10 PM 2/2/2007
Modified by DaBeastWthn at 7:11 PM 2/2/2007
Modified by DaBeastWthn at 7:24 PM 2/2/2007
Modified by DaBeastWthn at 7:26 PM 2/2/2007
*Good*
*New*
Hood
Air Filter
Fuel Filter
Valve Cover Gasket
Oil Pan Gasket
O2 Sensor
Battery
Starter
Shifter Bushings
Front Brake Pads
Clutch
All Fluids Flushed
Regular Oil Changes
*Mods*
D16Z6 Transmission
Short Shifter
17" wheels
*Bad*
kholmes
Dec 26, 2003 07:11 AM
