B18b in an Ek power steering problem
hey does anyone know how i would go about getting my PS back, i just installed a B18b turbo in my car, and i have both 00 ek Ps pump and brackets as well as 00 teg brackets and pump that came with the motor. If i use the ek pump with the teg brackets, the pump doesn't align with the crank pulley. and if i use the teg pump with the teg brackets, the fluid pipe doesn't fit into the top of the teg pump because it has a bigger diameter. and i dont really wanna machine the teg pump bigger unless a have too. and i dont wanna remove the PS line from the rack, cause that's a bitch. does anyone know what to do?
thanks
thanks
read
https://honda-tech.com/zerothread?id=1822781
best thing about honda-tech, is 99% of what you want to know has been covered in the past - searching will almost always yield the answer to any question
again
you need to use the upper bracket that matches the head....whether that is a pr4 pr p75 head...
bleedblue94
Jun 27, 2007 12:27 PM
