distributor
Old Jan 31, 2007 | 11:32 AM
keepitngga1's Avatar
Default distributor
there was a wierd sound comin from the distributor kinda like a little knockin,than at times the car would jus lose power and turn off..recently the car jus ran ok than it jus died on me and when i turn it on,it idles like at 200-300 rpms for about 3-5seconds and completely dies...
its obvious that somethin is wron wit my dizzy but why would it make that knockin sound??
Old Jan 31, 2007 | 11:38 AM
ef-hatchcrap's Avatar
Default Re: distributor (keepitngga1)
Take your dizzy cap off there is a little set screw that holds the rotor on. That screw came out and that is why your car wont run and there is that noise.
Tighten the crew and see what happens.
Old Jan 31, 2007 | 11:39 AM
jdmR_si's Avatar
the knockin can be something loose inside or the bearings could be bad. ur car shutin off can be the distributer can be over heatin which causes to turn off can be the ignitor or the coil but if its making noise internal like the bearings just get another one if thats not the only problem wit ur car
Old Feb 3, 2007 | 04:13 PM
Default Re: distributor (jdmR_si)
its the bearing..where would i jus get another bearing at?
Old Feb 14, 2007 | 07:21 PM
jdmR_si's Avatar
to much of a hard time to replace just go out and pick up a used one or if u wanna spend more buck buy a new distributor and keep the coil and ignitor for spare parts wen u might need them
SLIM NOTHING
Sep 8, 2010 09:37 AM
hondacivic90zc
May 18, 2008 10:53 AM
bleedblue94
Jan 7, 2006 10:08 PM
davekaro
Apr 3, 2004 02:38 PM
VTECisSeXY
Jan 24, 2004 08:12 AM
