BUILT b16 SWAP! gsr trans, p30 ecu, etc...
Alright guys, I'm going a different route w/ my car now, and need this engine gone so i can get some fundage for the new project
This motor has 1952 actual miles on it, and was brokin in accordingly. I'm located in Minneapolis, MN, and if anyone's really interested, I have vouches on other forums, will provide pictures and recipts, and will provide my phone number/adress for pick up, or to come check this guy out. My asking price on this is $3500. Here goes...
Built b16 swap, comes with engine, stock GSR trans, engine wiring harness, mounts, chipped p30 ecu, shifter linkages, and axles. I'm also throwing in a BMC log t3 manifold with a knockoff tial 38mm wastegate
Engine:
B16 block- stock sleeves, but block filled (if you don't know what this is, just pm me)
stock polished b16 crank
king main and rod bearings
ARP main and rod bolts
H beam rods
SRP pistons and rings
cometic hp headgasket
ARP headstuds
Clutch Specialties 8lb chromoly flywheel
Clutch specialties stage 4 clutch (6 puck, sprung disc)
Greddy timing belt w/ water pump and timing belt components
new oem oil pump
new seals everywhere
stock b16 head and intake manifold
hondata intake manifold gasket
dual valve springs (high rev) i'm also including the stock b16 valve springs
titanium retainers
oem honda valve stem seals
PM me with any questions!
This motor has 1952 actual miles on it, and was brokin in accordingly. I'm located in Minneapolis, MN, and if anyone's really interested, I have vouches on other forums, will provide pictures and recipts, and will provide my phone number/adress for pick up, or to come check this guy out. My asking price on this is $3500. Here goes...Built b16 swap, comes with engine, stock GSR trans, engine wiring harness, mounts, chipped p30 ecu, shifter linkages, and axles. I'm also throwing in a BMC log t3 manifold with a knockoff tial 38mm wastegate
Engine:
H beam rods
ARP headstuds
new oem oil pump
titanium retainers
Also willing to take trades. I'm lookin for a new-er big screen (42" and up) in particular. I'll consider trades for other things as well though, lemme know what you got
avblueshark
Aug 29, 2009 02:10 AM
Honda-bond
79
Jun 22, 2006 11:35 PM
