Koni Race Shock w/ Ground Control Springs.
Old Jan 31, 2007 | 07:49 AM
LunchboxZT's Avatar
Default Koni Race Shock w/ Ground Control Springs.
Okay! I am about to purchase my Shortened and revalved race shocks from http://www.redshiftmotorsports.com with the Ground Control Coilover and custom rated springs.
I read this frickin awesome write up here https://honda-tech.com/zerothread?id=891136
I currently have fully stock suspension setup.
I have 3 questions.
1) Is there still an issue with the stock upper mount being 10mm instead of 12mm? Can I drill it out myself or is it necessary to have it machined?
2) The bumpstops. Some people said a dremel needs to be introduced to make it fit, other people said they just punded it in with a BFH and it worked. any input on this?
3) Are there any additional parts I will need to buy for this swap? I plan on just buying the Koni Race Shocks w/ GC Coilovers straight from redshiftmotorsports. Can anyone think of anything else I might need to buy to make this work?
Thanks in advance.
Modified by LunchboxZT at 9:00 AM 1/31/2007
Old Jan 31, 2007 | 09:13 AM
GO-FIGHT-KILL's Avatar
The Ground Controls should come with aftermarket top hats that replace the stock upper mount.
If you're installing the Koni Yellows with a different spring (i.e Stock, H&R, TEIN S-Tech, etc), you have to have the 10mm bushing expanded to 12mm. Most take them to a machine shop and have them bored to 12mm, but a drill press works fine, as long as it's 12mm.
Good idea on the new setup, Yellow/GC is a very nice setup.
Old Jan 31, 2007 | 09:35 AM
citrus3000psi's Avatar
Default Re: Koni Race Shock w/ Ground Control Springs. (LunchboxZT)
For the price of that setup why not go with pic? They cost pretty close to same.
Old Jan 31, 2007 | 09:52 AM
jetydosa's Avatar
25 Year Member
Default Re: Koni Race Shock w/ Ground Control Springs. (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">For the price of that setup why not go with pic? They cost pretty close to same.</TD></TR></TABLE>
Go with who?
The race valve dKonis are bad *** I can tell you that.
Old Jan 31, 2007 | 09:53 AM
walker111's Avatar
Default Re: Koni Race Shock w/ Ground Control Springs. (jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">
Go with who?
The race valve dKonis are bad *** I can tell you that.</TD></TR></TABLE>
http://picperformance.com/store/scripts/news.asp
Old Jan 31, 2007 | 10:12 AM
I don't think "Koni's" can be listed as badass
Old Jan 31, 2007 | 10:16 AM
LunchboxZT's Avatar
Default Re: (citrus3000psi)
Koni = Lifetime warrenty and great customer support = badass
Modified by LunchboxZT at 12:37 PM 1/31/2007
Old Jan 31, 2007 | 12:45 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I don't think "Koni's" can be listed as badass</TD></TR></TABLE>
lolzel...
Old Jan 31, 2007 | 12:53 PM
Dave_B's Avatar
Default Re: (LunchboxZT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">Koni = Lifetime warrenty and great customer support = badass
Modified by LunchboxZT at 12:37 PM 1/31/2007</TD></TR></TABLE>
PIC's support is badass!!! They even sponser the Expo! I'm sure they'd hook you up
Old Jan 31, 2007 | 02:18 PM
jetydosa's Avatar
25 Year Member
LMAO, go over to roadrace-autox.com and say that.
Or, an F1 paddock for that matter.
I cant speak for PIC, they may be a good damper, but Koni makes an EXCELLENT shock and if you dont think so you are mistaken.
Luca
Suspension & Brakes
Nov 2, 2010 04:12 PM
jjep8704
Jul 6, 2008 09:11 AM
RDLIN-IT
Dec 1, 2005 06:48 PM
gribbs
Oct 15, 2003 12:16 PM
NoNOSgsr!
Apr 14, 2003 06:29 AM
