What kind of CATCH CAN are you running on your FU setup?
What kind of catch cans are you FI guys using? The recirculating one.. or an open filter one that releases into the atmosphere?
2 made by myself that vent to atmosphere through K&N filters. 2 lines from block, 2 from valvecover.
One can out of 3" dia piping, the other I made out of a power steering resevoir.
i have a chance to pick up a branew moroso for 60 shipped.. its polished too..
expletive it, ill get it..
Open element. I hollowed out the PCV valve and ran one line from the black box to the 1st fitting on the catch can and one line from the valve cover to the 2nd fitting on the can. I empty it at each oil change.
kms fab also with baffles inside and filters on top .one from valve cover and one from the block box (modified with two fittings welded to the can to use with -8 line) i have to drain eveyother month or so.
i will have a set up similar to t57b18 soon...but this was my set up on my all motor ls...
it's an electrical socket box...steel wool on the inside and it's been siliconed shut with one plastic nipple on one end for a breather filter and two on the other for the lines ran to the motor...and on the bottom there is a screw so u can empty it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan »</TD></TR><TR><TD CLASS="quote">i will have a set up similar to t57b18 soon...but this was my set up on my all motor ls...
wow..As an Electrcian,I've never seen some one us
a Outdoor Weather proof box like that before..
wow..As an Electrcian,I've never seen some one usa Outdoor Weather proof box like that before..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG »</TD></TR><TR><TD CLASS="quote">hmmmm...
this will be used on a VW VR6, but the concept is the same....
picture of the one im getting... (one inlet)
is this the baker one? i want to run the baker one but im not sure if its worth the $100 they want.
</TD></TR></TABLE>is this the baker one? i want to run the baker one but im not sure if its worth the $100 they want.
damn guys....I made both of mine free...with sheit I had laying around. Only thing I had to buy was some small fitlers.
$100 for a can, come on!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error »</TD></TR><TR><TD CLASS="quote">is running a catch can set-up absolutely neccessary? whats wrong with the stock pcv set-up?</TD></TR></TABLE>
pvc is a check valve, underboost it is closed so the gases dont vent.
I will be running the Moroso one but will add one more nipple so I will have 2 fittings on it for the valve cover. Need to add a fitting onto the VC as well.
Then I will have one medium size Greddy catch-can for the block, that will be connected to my Exhaust excavation system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">damn guys....I made both of mine free...with sheit I had laying around. Only thing I had to buy was some small fitlers.
any pics of yours?
</TD></TR></TABLE>any pics of yours?
