eg coupe b18b
Old Jan 30, 2007 | 06:43 PM
94 ls teg's Avatar
Default eg coupe b18b
i got a 95 civic ex and picked up a complete b18b obd2 i know u need axles and all the mounts ecu but what else do u need
i know it a noob question
Old Jan 31, 2007 | 12:51 PM
94 ls teg's Avatar
Default Re: eg coupe b18b (94 ls teg)
anybody
Old Feb 1, 2007 | 11:34 PM
zerovandez's Avatar
shift linkage if it's a 5speed.
Old Feb 2, 2007 | 04:36 PM
unknown0001's Avatar
-since it's obd-2, you will need an obd-1 to obd-2 conversion harness
-94+ integra axles
-94+ integra shift linkage
-mounts
-upper/lower rad hose
Old Feb 3, 2007 | 05:28 PM
94 ls teg's Avatar
Default Re: eg coupe b18b (Mr.RHTuner)
does anybody know where to get the conversion harnes or can u make one out of the two harnes
Old Feb 3, 2007 | 07:46 PM
-GRIFFIN-'s Avatar
well my 93 civic hb has a 99 b18b installed and no conversion harness was used,
who ever did it , rewired everything and did a real excellent job
so it can be done
joe griffin
Old Feb 4, 2007 | 11:31 AM
94 ls teg's Avatar
Default Re: eg coupe b18b (-GRIFFIN-)
thanks joe i got the hole harness out of the integra so me and my buddie r going to try and get it to work with the two harneses want it to be nice and clean
Old Feb 4, 2007 | 03:16 PM
kiddcarbuff's Avatar
use an obd1 p75 ecu, use the obd2 engine hanbress, it WILL plug into the obd1 chassis harness
Old Feb 4, 2007 | 03:55 PM
-GRIFFIN-'s Avatar
Default Re: (kiddcarbuff)
just remember to take your time and if your not sure about something just ask theres tonns of pepole to help out
anytime
joe griffin
Old Feb 4, 2007 | 06:24 PM
94 ls teg's Avatar
so then all i need is a p75 for obd1 and my swap will go a little easy does anybody want to trade a p75 obd2 for a p75 obd1 or sell
Old Feb 4, 2007 | 10:56 PM
integrainside's Avatar
OBD2 to OBD1 conversion harnesses are all over ebay for $75-$100
Old Feb 5, 2007 | 10:08 AM
-GRIFFIN-'s Avatar
Default Re: (integrainside)
well they never used a obd 1 p75 ecu in mine , i got a pr4 running mine right now , should i be using the p-75 ecu ????
rhdekhatchie
Dec 14, 2008 07:05 PM
pine_apple45
11
Mar 20, 2007 08:12 PM
I got a honda
Jan 15, 2006 07:17 PM
solsi2000
Dec 8, 2004 02:05 PM
