3rd Gen How To: Clutch Adjustment?
There is too much pedal travel before engagement on my '90 Prelude. How do you tighten up the clutch pedal.
A clueless old man thanks you for your help.
Scott
Scott
im almost willing to bet you can use this same procedure:
https://honda-tech.com/zerothread?id=1859981
Just find your clutch cable, and follow it down, and there will be a rubber sleave that covers the adjuster, pull up the rubber sleave and twist the adjuster clockwise i do believe to tighten it, counter to do the opposite. easy stuff.
jACO 09
Apr 13, 2011 11:10 AM
