oil smoke when i rev hard
Old Jan 30, 2007 | 04:53 PM
Boosted ED9's Avatar
Default oil smoke when i rev hard
So I have a Crx Si, and it has a swapped SOHC ZC.
the guy who owned it before me was an idiot and couldn't drive im guessing, but i first thought that I had bad gaskets or my rings where going bad or already where bad. but anyways, I took it to Jiffy lube at my friends work, and we went underneath my car and saw that I had a bad bad oil leak, but it didn't drip just soaked everything under neith. The told me it could be a bad oil gasket and that i could just be burning oil threw my exausht, because when i hit like... 5grand or something blue smoke comes out. I checked my plugs and there is no oil at all in there.. and as far as burning oil threw my exausht, I thought it could just be my oil gasket, but im not sure if that would cause that much oil to be soaked down there
I have no clue what it could be because I've had all sorts of things told to me.
if somebody could help me out, That'd be awesome.
Old Jan 30, 2007 | 05:13 PM
SIred91's Avatar
Rainman
Default Re: oil smoke when i rev hard (Boosted ED9)
Here is a tip there, hero,
DONT REV HIGH AND HARD ITS NOT A RACE CAR!!
Most likely your rings are worn and or your valve stem seals as well.
"oil gasket"? what "oil gasket" are you talking about?
Old Jan 30, 2007 | 06:48 PM
welfarepc's Avatar
your burning oil, and leaking oil... take it to a mechanic if you dont know why its burning, or where its leaking. if you do know why and where, tell us so we can actually help
Dan
Old Jan 30, 2007 | 07:45 PM
ekslax's Avatar
71.172.180.139
samething was happening in my sedan, valve seals fixed it right up.
Old Jan 30, 2007 | 08:16 PM
viciousef9's Avatar
it sound like the rings are gone. i hahve the same problem now. i say you should just go pick up a motor instead of rebuilding it unless you plan on doin something with it.
PACT man's Avatar
Default Re: (ekslax)
Yea, a high rev oil loss/burn is usually the valve seals. And by oil gasket I hope you mean oil pan gasket and therefore would have oil dripping down onto your exhaust pipe and burning off...
Old Jan 30, 2007 | 08:25 PM
Default Re: (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">Yea, a high rev oil loss/burn is usually the valve seals. And by oil gasket I hope you mean oil pan gasket and therefore would have oil dripping down onto your exhaust pipe and burning off...</TD></TR></TABLE>
thats what I was told could be the problem, I was told to replace that and it'd be fixed, but I was just wondering if people where having the same problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Here is a tip there, hero,
"oil gasket"? what "oil gasket" are you talking about?</TD></TR></TABLE>
haha, I'm not even "revving" it high, it just smokes when i hit 4-5k.. and by Oil gasket, i figured everybody would know what i ment since the only "oil gakst" would be my oil pan gasket, but ohwell.
I was going to swap a d series turbo kit on it, but I dont want to blow **** up untill i figure out whats going on.
and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">your burning oil, and leaking oil... take it to a mechanic if you dont know why its burning, or where its leaking. if you do know why and where, tell us so we can actually help
Dan</TD></TR></TABLE>
I could take pictures or something of where its leaking, and everything if that helps.
thanks for all the feedback people.
IntegraType-R
25
Nov 5, 2007 04:58 PM
wm5holla
May 19, 2003 07:30 PM
Pinpid
Dec 17, 2002 04:55 PM
CivicBoi
May 27, 2002 11:59 AM
