engine swap
Old Jan 30, 2007 | 02:03 PM
WhatsAClutch99's Avatar
Default engine swap
i know this is a newbie question but would you guys recommend an ls vtec swap in an 99 civic? I'm tryin to do a legal and reliable swap. Also another noob question but after the engine, ITR tranny, installation, LS ARP rod bolts
GSR ARP head studs
New OEM LS (90-01) B18a/b head gasket
New OEM/ACL LS bearings
Shotpeen LS rods
New hastings/OEM LS piston rings
New OEM valve seals
Hone cylinders
New GSR/ITR 22T water pump (P72)
New GSR/ITR timing belt (P72)
New GSR/ITR/96+ Bseries oil pump (P72)
Magnetic oil drain plug (important for break in)
New NGK V-power BKR6E spark plugs (stock pistons) OR NGK V-power BKR7E spark plugs for 10.8:1+ compression.
(i got that from honda-swap.com)
how much money am i lookin at? once again i know that is a noob question but i need to know how much money k-wise (3k-4k-5ketc.) i have about 2k saved up so i think im off to a good start.
thanks'
erik
Old Jan 30, 2007 | 02:05 PM
ekb16's Avatar
for a legal and reliable motor, i wouldnt rec. a lsvtec...b16a2 will be reliable for ur car and legal also unless u can find a b18c1 thats the year is 99+...use the search there is alot of info on these things
Old Jan 30, 2007 | 02:55 PM
Default Re: (ekb16)
still id like to get a price range so i know what im in for
Old Jan 30, 2007 | 03:06 PM
Default Re: (WhatsAClutch99)
plus i wasnt really lookin for a b16 becuase b16= no torque
Old Jan 30, 2007 | 03:12 PM
Syndacate's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">for a legal and reliable motor, i wouldnt rec. a lsvtec...b16a2 will be reliable for ur car and legal also unless u can find a b18c1 thats the year is 99+...use the search there is alot of info on these things</TD></TR></TABLE>
For the 99 thousandth time, a LS/V is just as reliable as any whole motor if it's assembled right.
EDIT:
@ OP: Search a place like http://www.slhondaparts.com for OEM parts and wherever you plan on buying your aftermarket parts.
In conjunction with the "add" button on a calculator you can come up with some ****.
honda97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhatsAClutch99 &raquo;</TD></TR><TR><TD CLASS="quote">plus i wasnt really lookin for a b16 becuase b16= no torque</TD></TR></TABLE>
i have been trying to fig out what motor i wanted. i was going to get a b16 installed for $1900. but then i looked more. even tho i dont have all the money right now i am just going to wait and get a b18c gsr. so in about a month i should have it in my car i cant wait anymore, lol!!!!!!!!!
Old Jan 30, 2007 | 03:13 PM
honda97hb's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
For the 99 thousandth time, a LS/V is just as reliable as any whole motor if it's assembled right.</TD></TR></TABLE>
x2
Old Jan 30, 2007 | 03:15 PM
Syndacate's Avatar
Default Re: (honda97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda97hb &raquo;</TD></TR><TR><TD CLASS="quote">
i have been trying to fig out what motor i wanted. i was going to get a b16 installed for $1900. but then i looked more. even tho i dont have all the money right now i am just going to wait and get a b18c gsr. so in about a month i should have it in my car i cant wait anymore, lol!!!!!!!!!</TD></TR></TABLE>
Yes.
B16's are great motors...fun as ****, not good daily drivers though unless boosted in my opinion.
Or they're fine daily drivers, but not much of an upgrade than a D-series motor if you're daily driving it (oppose to "street racing").
Old Jan 30, 2007 | 03:23 PM
honda97hb's Avatar
Yes.
Or they're fine daily drivers, but not much of an upgrade than a D-series motor if you're daily driving it (oppose to "street racing").</TD></TR></TABLE>
x2 i got a 97 hatch and i drove a 97 hatch with a b16 (with H/I/E n a clutch) the other day first the first time and like syndacate said, there the same as a d16 until you hit like 5k. so unless your going to beat the **** out of your car 24/7 or but some FI in it its not much of an upgrade. only very very little more torque.
Old Jan 30, 2007 | 03:28 PM
honda97hb's Avatar
Default Re: engine swap (WhatsAClutch99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhatsAClutch99 &raquo;</TD></TR><TR><TD CLASS="quote">i know this is a newbie question but would you guys recommend an ls vtec swap in an 99 civic? I'm tryin to do a legal and reliable swap. Also another noob question but after the engine, ITR tranny, installation, LS ARP rod bolts
GSR ARP head studs
Shotpeen LS rods
New OEM valve seals
Hone cylinders
thanks'
erik
take my work on this! do a lot of research on this b4 you go buy a b16! an b18 is just as reliable as a b16!!!!!!!!!!
2000EKCoupe
11
Jan 31, 2012 07:25 PM
92integraVTECgsr
102
Sep 10, 2008 07:12 PM
importsalltheway
Jun 4, 2008 09:28 AM
dc2_lsvtec
Jul 29, 2005 06:33 AM
boostaholic
Oct 2, 2003 09:24 PM
