CAR WONT START (please help)
i have a crx wit a b18b1 swap. my car wont start. im getting fuel pressure (35psi) which should be enough to turn it on, i've got spark, new spark plugs and wires, my timing is on point but it wont turn on. i've replaced the main relays, ecu, and i've checked wire for wire with a tester and every thing is working fine. my car was running perfect, as is, for like 3 months and one day i parked it, turned it off, and it didnt wanna tun back on. i did a compression test and everything was fine. i'm really going crazy with this car and i need help.
i had spark, fuel, and compression...also brand new main relay...and no codes the car would crank crank and crank..took off the fuel rail, primed it a few times..let them spray into a rag or old t shirt so it doesnt get all over..
injectors are prob clogged
gsrboost737
Apr 16, 2009 11:38 PM
Any ECU codes at all?
