23mm JDM ITR rear swaybar bushing brackets and ITR specific lowering springs?
Old Jan 30, 2007 | 12:46 PM
b18c4door's Avatar
Default 23mm JDM ITR rear swaybar bushing brackets and ITR specific lowering springs?
Anyone on here have the JDM 23mm rear swaybar and if so what bushings and bushing brackets do you use? I can find the bushings on ebay, but no brackets. Not sure if the USDM bracket will work - per some guy on the Integra forums, it will.
I plan on using this with some ITR LCA's and ITR specific suspension - which leads me to another question:
Are they any aftermarket people who produce ITR specific lowering springs or is it generally for all Integras - The used comptech ones I bought say for 94-01 Integra (All) and was hoping this would work with some ITR specific Koni yellows or Bilstein Sports...
Thanks!
Old Jan 30, 2007 | 12:47 PM
OG undercover's Avatar
Default Re: 23mm JDM ITR rear swaybar bushing brackets and ITR specific lowering springs? (b18c4door)
Use the 22mm bushings and brakets, NP
Old Jan 30, 2007 | 12:56 PM
b18c4door's Avatar
Thanks, you ITR guys rock! much more mature and have civil discussions. Wish I was a part of this group, sometimes!
Old Jan 30, 2007 | 04:43 PM
SlapSmak's Avatar
Default Re: (b18c4door)
you can also use the energy suspension bushings.. a little harder and grease-able. They come with the brackets. I think mine were about 25-30$ as I recall...
Old Jan 30, 2007 | 05:02 PM
jetydosa's Avatar
25 Year Member
Default Re: (SlapSmak)
Yeah the 22mm will work fine with some patience
jizzer671
Suspension & Brakes
Apr 2, 2007 01:04 PM
mrdeadman
Mar 20, 2006 03:56 PM
cedete
Nov 8, 2004 07:18 PM
GTScott
Oct 28, 2003 06:22 PM
keys
May 17, 2002 06:07 AM
