ABS Unit, Could I remove without replacing everything?
Old Jan 30, 2007 | 11:54 AM
GraphiteMW's Avatar
Default ABS Unit, Could I remove without replacing everything?
I was removing my back seats and removing the rear side panels to redye my cloth and I saw the ABS unit.. its massive. Could I remove this unit without having to replace my brake lines etc? Or should I leave it alone?e
Old Jan 30, 2007 | 12:06 PM
ninja 6's Avatar
Default Re: ABS Unit, Could I remove without replacing everything? (GraphiteMW)
i assume you drive a 4th gen?
no you can't remove it without replacing everything. the actual unit itself is tied into the brake lines
you would need to get new brake lines
Old Jan 30, 2007 | 12:20 PM
GraphiteMW's Avatar
Default Re: ABS Unit, Could I remove without replacing everything? (ap)
Thanks looks like i'll be keeping it.
Old Jan 30, 2007 | 12:25 PM
ninja 6's Avatar
yeah, its not worth the 40-50 lbs (or whatever the hell it weighs)
If you want to turn the abs off for racing/autocross, keep the e-brake up (just enough so that the brake light is on) for a few seconds while driving until your abs light comes on, and your abs will turn off. then release the e-brake.
richjr
Oct 6, 2008 04:21 PM
msinsky14
Nov 29, 2006 08:44 PM
orangebarius
Sep 11, 2004 08:20 AM
