Buying a car that has been staying outside for 1 year
Hello,
I´m considering of buying a Civic from 1990 that has been staying still for a year (in a country where it snows in winter). What are the problems that may arise when trying to get it running and ready for road(excl. bodyworks) ? I must change the belts and everything that it includes. Also the fluids must be changed including brakefluid+brake adjusting. I have heard that one possible problem that may arise with fuel lines and brakelines that might be rusted through. Anything else that should be considered?
Tnx in Advance
Henrik
Tnx in Advance
Henrik
check all fluids levels
jack up car, with tires on move them from side to side, feeling for anything loose
check tie rods, balljoints, sway links, all bushings
check handbrake mechanism and cables
check all brakes/ clean and adjust rear drums
check exhaust/heatsheilds for noises or looseness/rattle
check fuel and brake lines
while under the car, check under the block for any leaks (especially around gaskets)
check belts and hoses, check rad
look for any signs of rust
check all filters and pcv
check/clean throttle
check all lights
check all accessories
check a/c
check spark plugs
umm i know there more, but im just typing off of my head
check all lights
check a/c
check spark plugs
