Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brake noise when heavy braking
Old Jan 30, 2007 | 11:03 AM
CSLKid's Avatar
Default Brake noise when heavy braking
We replaced the Standard pads on my friends Civic Sport a couple of days ago as they were worn down alot.
We replaced them with Ferrodo Pads and althought the braking is just as good, if not better with these pads, when the ABS kicks in there is a rattly/rapid vibration coming from the left hand side of the car.
Anyone any ideas? I've checked all bolts I worked with and they're fine and tight.
Thanks in advance people.
Old Jan 30, 2007 | 11:07 AM
toyomatt84's Avatar
Sanji
What year/model of the car is it? Civic Sport doesn't help much.
Old Jan 31, 2007 | 12:37 AM
CSLKid's Avatar
Sorry mate, I feel like a total loon.
Erm its a 2004 model, 3 Door 1.6 v-Tech. The model number I am not sure about, not really honda minded. Hope this helps!
Old Jan 31, 2007 | 02:26 AM
Curiouz_G's Avatar
BMW minded then?
as for your braking, when ABS usually kicks in, there is a pumping sensation coming from your pedal. depending on which side is slipping, you might only get that feel from 1 side of the car
Old Jan 31, 2007 | 05:21 AM
CSLKid's Avatar
Aye, he said it wasn't doing it before though, thats what I don't understand.
Yes, I am BMW minded. Love the rear wheel drive, and an M3 CSL is the car to have IMHO. I love it. Anyway, back on topic lol
Old Jan 31, 2007 | 08:10 AM
toyomatt84's Avatar
Sanji
Ahh, so you're from Europe, aren't you? That helps a bit, as well, since you get different models than we do. The 1.6L Sport that you're referring to, is a Europe-only model, so getting help with drivetrain problems might be a little tough from a predominantly United States forum. Not saying that it's impossible, just saying it might take a while. You may want to try the Acura RSX/Honda Civic EP3 forum, seeing as your 1.6 mainly resembles the Civic EP3.
Old Jan 31, 2007 | 08:47 AM
Newborn_'s Avatar
Grace Under Pressure
I'm a little familiar with your car mate, i'm from England. EP2, i think it is...?
But from what you say it sounds like you've done everything right, and without looking at it or having a bit more info, it's hard to say what it could be really.
Maybe try re-checking EVERYTHING again? Even the things you didn't touch that are around that area.
Make sure you've got no stones or grit or anything stuck behind the backplates or whatever... i dunno, i'm clutching at straws here, lol.
Like Matt said, try the other forum or try civicsportsclub.co.uk or civiclife.net, both UK sites with EP owners on. Hope that helps ya mate
Old Jan 31, 2007 | 02:52 PM
Amped's Avatar
Default Re: Brake noise when heavy braking (CSLKid)
did you replace the rotors? If you didn't, the rusty lip on the outside of the rotor may be causing a noise.
Old Jan 31, 2007 | 10:05 PM
LowTec MOHawk's Avatar
if you still have the old pads ..............try putting them back on and seeing if the sounds is there or not. it might be a charateristic of the new pads, considering they arent oem
jmartinez198
42
May 21, 2018 04:59 AM
raidacaipo
Sep 9, 2010 05:59 PM
Kcoolby
Jan 30, 2007 11:59 PM
KJ
Jun 26, 2001 02:29 PM
