Fuel Gage
Old Jan 30, 2007 | 09:19 AM
tigueremalo's Avatar
Default Fuel Gage
fuel gage not workin correctly..
could it be fixed and how?
or am i going to need to replace the fuel pump?
Old Jan 30, 2007 | 11:20 AM
limpy's Avatar
Default Re: Fuel Gage (tigueremalo)
if i remember correctly the fuel pump doesnt send the signal for the gage. the is a seperate sensor that is accessable from under the plastic tray (crx) or back seat (civic). but as far as changin it i would recomend that you atleast trouble shoot (make sure all wires are connected, try good none cluster, ect..)before you go and waste money on stuff you really don't need.
Old Jan 30, 2007 | 03:11 PM
charlee's Avatar
what is it doing? is it reading above or below?
Old Jan 30, 2007 | 03:20 PM
B16CRXT's Avatar
you should check all the wiring for the sensor. I doubt the gauge itself is faulty.
Old Jan 30, 2007 | 03:35 PM
Crx Jimmy's Avatar
Default Re: Fuel Gage (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">you should check all the wiring for the sensor. I doubt the gauge itself is faulty.</TD></TR></TABLE> the gauges do go out, you can still buy it new from honda its not that expensive. but check every thing out first, you can check operation of the sending unit with a volt meter
Old Jan 30, 2007 | 03:59 PM
dr_latino999's Avatar
Default Re: Fuel Gage (Crx Jimmy)
If your Gas-ometer (I like the term, STFU) has been found to still be operational the part that has failed is the Fuel Meter Sender.
REPLACE
15 - 37800-SH3-003 - $37.42
16 - 37801-689-000 - $2.04
Old Jan 30, 2007 | 07:02 PM
Default Re: Fuel Gage (charlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee &raquo;</TD></TR><TR><TD CLASS="quote">what is it doing? is it reading above or below?</TD></TR></TABLE>
dude my car almost left me on the highway last night but yea anyway am i had a empty tank and my gage said i had a quarter tank!!!!!!
changknows
11
Sep 7, 2009 02:29 AM
Rikaro
Apr 25, 2007 03:57 AM
esoterEK..
10
Feb 22, 2005 02:40 PM
drunknbass
Aug 7, 2003 04:06 PM
