So what's the difference between LSVTEC and TYPE R
Old Jan 30, 2007 | 05:58 AM
haveaNOSday's Avatar
Default So what's the difference between LSVTEC and ITR motors.
So what's the difference between LSVTEC and TYPE R anyways...
From what I've read, and what I've learned, I know that the ITR has better goodies like a crank girddle,thinner in. valve stems, oil squirters,pnp head, cams,ect. from what I know the b18c5 block is the same height, the pistons and rods are the same (just made of different construction) the heads are the same cast. so on and so on....Basiclly when building an lsvtec setup your immitating a type r... IMO!!! So unless you buy all the type r goodies then install them on your lsvtec you end up with a b18c5 with the motor stamped b18a1 and minus the oil squirters hence "poor mans type r" I'm not hating, I'm just in the middle of building an lsvtec and it's a real pain in the ***. Like switching pistons,matching bearing codes,buying lsvtec kit ect,ect. I'm sure you guys understand.
I'm running
pr3 pistons (sir in canada)
pr4 rods (ls in can.)
pr4 crank(again in can.)
b18a1 block
Type r mains bearings which are Pr3(in can.)
Ported and polished head "by me!"
head decked .020"
all stock pr3 valve hardware
ITR cams
modified to 3" DP stock SIR ex. mani./
all arp hardware..rod bolts,main bolts,headstuds.
fidanzza FW
p28/hondata s200
Pretty much a type r give or take a couple of things. This set up better be faster by alot compared to a b18c5 in a civic, or else everythings for sale!!!
....any thoughts??
Modified by haveaNOSday at 10:45 AM 1/30/2007
Old Jan 30, 2007 | 06:23 AM
b19coupe's Avatar
Default Re: So what's the difference between LSVTEC and ITR motors. (haveaNOSday)
About $3000
ITR/GSR rod bearings are different from LS rod bearings. The mains are the same.
The ITR reciprocating assembly is better balanced from the factory, and the 87.2mm stroke is arguably better than the LS 89mm stroke when it comes to high rpm power. If you think that your LSVTEC should be faster than an ITR swapped Civic, you may be in for disappointment.
Old Jan 30, 2007 | 06:44 AM
thats exatly what I thought.
But with thin 89mm rod journals do you think torque would be increased slightly resulting in less rpm and more power??
Old Jan 30, 2007 | 07:12 AM
Honda Bull's Avatar
Default Re: So what's the difference between LSVTEC and ITR motors. (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote"> If you think that your LSVTEC should be faster than an ITR swapped Civic, you may be in for disappointment.</TD></TR></TABLE>
What if that said LSVTEC was bored to 84mm, running 11.8:1 compression, ITR tranny, and big cams?
Old Jan 30, 2007 | 07:32 AM
b19coupe's Avatar
Default Re: So what's the difference between LSVTEC and ITR motors. (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">What if that said LSVTEC was bored to 84mm, running 11.8:1 compression, ITR tranny, and big cams? </TD></TR></TABLE>
Then he would be disappointed for sure
Old Jan 30, 2007 | 08:05 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
werd!!
Old Jan 30, 2007 | 09:01 AM
you would need sleeves in that case you can't bore stock b18 sleeves to 84mm
Old Jan 30, 2007 | 10:28 AM
D-Rob's Avatar
Default Re: (haveaNOSday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">About $3000
O RLY?
Where's this ITR swapped Civic at?
Damn, you beat me to this.
- Derek
Nichelson_Performance
10
Feb 6, 2009 04:23 PM
00Red_SiR
Sep 23, 2004 03:44 PM
bk92teg
Aug 20, 2004 08:32 PM
DoctorGSR
Aug 17, 2003 09:35 PM
OEMJDM
Aug 28, 2002 08:12 PM
