95 civic ex --> si conversion?
Um...EX was a coupe or a sedan, the SI was a hatch. THey have the same motor and options. Conversion would require a plasma cutter and a big *** hammer.
yeah, i don't understand the question. my 93 ex is the same as a friends SI, except his valve cover said VTEC on it. 95 i'm assuming are the same, unless you thing there is a conversion kit to turn a coupe into a HB, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadalac1712 »</TD></TR><TR><TD CLASS="quote">i mean like the body. ilke the 99-00 coupe. or is it type r kit im looking for?</TD></TR></TABLE>Um...completely different bodies. That'll be a metric f-ton of fiberglass and urethane to make that happen. Why not just buy an SI shell and build it yourself? It seriously might be easier. Unless you're just looking for a bumper/skirt kit and headlight conversion, in which case this should really be in the appearance/cosmeti c forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si »</TD></TR><TR><TD CLASS="quote">I've seen a 92-95 with a 2000 font end on it. **** I've seen a 91 hatch with an integra front end on it.</TD></TR></TABLE> So have I. Both were hard core swaps, and it took a ton of work, welding, panel fitting, bondo, fiberglass, and paint work to make it happen. There isn't a kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton »</TD></TR><TR><TD CLASS="quote"> So have I. Both were hard core swaps, and it took a ton of work, welding, panel fitting, bondo, fiberglass, and paint work to make it happen. There isn't a kit.</TD></TR></TABLE>
and its not worth the time and money you will spend
1stcivic
Dec 15, 2005 06:38 PM
basik
May 1, 2005 01:29 PM
ForceFed Coupe
Dec 3, 2003 12:30 PM
