Chicago & Illinois: FS/FT WTB, Feb 2007 <~Bears 2k7 Superbowl Champions~>
Old Jan 30, 2007 | 04:16 AM
Akiraboy's Avatar
Default Chicago & Illinois: FS/FT WTB, Feb 2007 Bears 2k7 NFC Champions
for sale
88hf
97 eclipse gsx
b16 head
b16 IM with everything on it
b16 running shortblock
b18a block
d16a6 head
d16z6 head
14b disassembled
wanted
all this ish gone
Modified by Akiraboy at 8:59 PM 2/4/2007
Old Jan 30, 2007 | 05:27 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: Chicago & Illinois: FS/FT WTB, Feb 2007 <~Bears 2k7 Superbowl Champions~> (Akiraboy)
1998 Civic CX perfect condition - low miles
https://honda-tech.com/zerothread?id=1859526
Civic Ex cluster - carbon fiber surround 88k miles
http://www.hondamarketplace.co...68747
Old Jan 30, 2007 | 06:57 AM
splitime's Avatar
FS: 1 Innovate LM-1 RPM kit.
Includes:
1x LM-1 Unit
1x O2 sensor
1x LM-1 to PC Serial Cable
1x Sensor cable
1x Power Cable
1x RPM pickup
1x RPM Converter (Aux Input #2) (can log 4 0-5v inputs)
My favorite unit on the market. I don't need 2 of them though. So pickup my spare for a deal
From Innovate:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The LM-1 is the industry's first and best complete wideband tuning system. A single self-contained unit combines a wideband air/fuel ratio sensor controller, a 6-channel data logger, and an easy-to-read backlit LCD display. This is the unit used by tuners, racers, and engine builders the world over.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
* World's only fully-digital wideband controller.
* Up to 6 Channels of data logging.
* Portable/ Handheld.
* Display both A/F and Lambda readings in real-time.
* Auto calibration to compensate for changes in temperature, altitude, and sensor condition.
* Two user configurable analog outputs.
* LogWorks - award winning tuning software.
The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included LogWorks software or any standard spreadsheet program:
The LM-1 also features two analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 1 volt = 10 AFR (.6 lambda) and 2 volts = 20 AFR (1.3 lambda). With the provided LM Programmer software these analog outputs may also be configured by the user.
RPM KIT:
The RPM Kit ($429) is comprised of the basic kit plus the LMA-2 (RPM Converter.) This cable contains a circuit to convert a tach signal into an analog RPM signal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other 0-5 V analog sensors from your vehicle
All gear needed for $325 Fairly FIRM. This is confirmed working and is one of the nicest units on the market. Onboard datalogging = sex.
I can also plug in the LM-1 box to my car and display its working 100% for buyer. Just an extra confirmation
ALSO FOR SALE:
1994+ Manual LS DC2 Gauge Cluster. ~150k on it. - 50 obo.
Chipped PM6 ECU - will burn with a program for you. Has ZIF (zero insertion force socket for easy chip swapping) and datalog header. - 100 pickup/meetup.
Old Jan 30, 2007 | 07:37 AM
Lewy. Dee Ayy's Avatar
FS: z6 Trans $150.
DC headers off a z6 $100.
Black Eg hatch cover $50 bucks
D Series Starter make offer
GSR throttle body (no butterfly)
h22 intake manifold
D series Clutch
15in Steelies and tires
Wheel Spacers
13in hubcaps
two Intercoolers (i think one DSM and one Supra) but im not sure
h22 AC compressor
H22 Aluminum AC bracket
Integra Rear Trailing Arms And Calipers
H22 Oil Pump 1k miles on it
pm5 ecu
a6 head
two Ek hatch mudflaps
Stock EK rear Trans bracket and mount
PM for price for anything without a price. and pic's
Modified by Lewy. at 9:24 PM 1/30/2007
Modified by Lewy. at 1:12 PM 1/31/2007
Old Jan 30, 2007 | 07:55 AM
AlienKrOZ's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, Feb 2007 <~Bears 2k7 Superbowl Champions~> (Lewy.)
WTB: Projector retrofitting service.
Old Jan 30, 2007 | 08:00 AM
midwesta's Avatar
Okay I am parting out a 1997 Acura Integra LS Sedan.
I also have many parts from two 1994 Acura Integra GSR Sedans.
AND I also have many parts from a 1995 Acura Integra LS Coupe.
AND I also have many many EG parts from SI/DX/CX
ANYTHING YOU CAN THINK OF THAT YOU NEED THAT IS OEM FROM ANY INTEGRA OR ANY CIVIC, PLEASE PM ME AND I MOST LIKELY HAVE IT!!!!!
I am not going to take pictures of little things because we all know what they look like, and I really dont want to make a list because I know I will forget something, or list something I do not have. When you pm me to ask about a part, and I have it, I will not be able to take pics, unless it is something worth over 100 dollars. I will tell you the condition of the part, and I usually wont sell something unless I would put it on my personal car if I needed it. I throw other **** away.
If you are local, you can come by and check out the parts, I am mostly available Friday, Saturday, and Sunday. Parts are located near Crystal Lake, IL 60014.
If you are not local, and need the parts shipped, I am paypal verified, and have many vouches. Again, I will not be able to ship the parts til Friday or Saturday. So please keep that in mind.
I need **** cleared out because my basement is full, and my bedroom at home is where I am storing parts and my mom is pissed.
So please pm me and let me know what you need/want and I will get back to you ASAP.
Here are pics of the pile up starting in my room. Lets get rid of this ****.
Old Jan 30, 2007 | 08:03 AM
ken00si's Avatar
Default Re: (midwesta)
WTF...2 weeks ago this guy told me that his garage was broken into and all his parts were stolen, and now he relists everything???!!!
Yo jdmsi1320, I'm still interested in those Si seats if you still have them. Let me know asap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsi1320 &raquo;</TD></TR><TR><TD CLASS="quote">FOLLOWING ITEMS ARE FOR SALE. PRICES ARE NOT SET IN STONE
*99-00 OBD2 AEM EMS $850
*B-SERIES OMNI FLAT VALVES STND SIZE
$120OBO
* B-SERIES TODA HEADER MINT $700obo
*96-00 CIVIC RS-R GT2 CATBACK & CUSTOM TEST PIPE $275obo
*H22 FULL BLOCK $400OBO
*OEM B18 LS CRANK GOOD CONDITION $100OBO
*TODA VALVE SPRINGS MINT CONDITION 1500 MILES ON THEM $220OBO
*CP FORGED PISTIONS 11-5 COMPRESSION 84MM BORE WITH RINGS ONLY 1500 MILES ON THEM $375OBO
*GOLDEN EAGLE SILVER VACUUM MANIFOLD WITH FITTINGS $40 OBO
*BRAND NEW STILL IN BOX ZEX NITRIOUS DIRECT PORT KIT INCLUDED EVERYTHING AND ALL SHOTS, BLOW DOWN TUBE, AND FULL BOTTLE $475 OBO
*96-00 CIVIC/INTEGRA NO NAME REAR STRUT BAR, POLISHED, $40 OBO
*99-00 CIVIC SI FRONT SEATS IN GOOD CONDITION $160 OBO
*99-00 CIVIC SI REAR SEATS AND PANELS $75 OBO
*99-00 CIVIC SI STEERING WHEEL WITH AIRBAG $50 OBO
*AUTOPOWER 6POINT ROLL-BAR EG/EK $275 OBO
*99 CIVIC OEM HOOD MINT CONDTION WHITE $120 OBO
*99 CIVIC OEM TRUNK MINT CONDITION WHITE $85 OBO
*96-00 CIVIC COUPE REAR SIDE WINDOWS OEM MINT CONDITION $80 TAKES BOTH
*99-00 CIVIC BLACK INVADER FIBER GLASS HOOD $80OBO
Anyone intersted in these parts or have any question email me at jdmsi1320@yahoo.com or you can call me, sean, at 847-924-6828. ALL PARTS ARE IN GREAT CONDITION JUST CHANGED MY WHOLE SETUP AND THESE ARE WHATS LEFT OVER
Old Jan 30, 2007 | 09:18 AM
thapimpfromchi's Avatar
Default Re: (ken00si)
Does anyone want a custom built computer? Me and my bud are tryin to start our out business. We can put together just about anything you can think of. PM me if you are looking for anything.
F.S. my personal computer
AMD Athlon 64 Processor
Asus Motherboard
1.5 GB ram
200 gb sata hard driv
8ch sound
Nvidia 6600 graphics card
CD-RW drive
DVD drive
Gamer case with LED's
Aftermarket Power supply
TV Tuner card with aux In
wireless network card
Running Windows Media center edition
askin 900. can remove stuff as needed. thanks.
Old Jan 30, 2007 | 09:22 AM
DisOnesAPlaya's Avatar
Sorry guy The COLTS ARE TAKING THIS ONE..
Old Jan 30, 2007 | 09:26 AM
splitime's Avatar
Default Re: (DisOnesAPlaya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DisOnesAPlaya &raquo;</TD></TR><TR><TD CLASS="quote">Sorry guy The COLTS ARE TAKING THIS ONE..</TD></TR></TABLE>
Go back to your crappy beer and cheese. This isn't a WI thread.
Old Jan 30, 2007 | 09:28 AM
SOHC_2_DOHC's Avatar
X2. GO BEARS!!!!!!!!!!!!!!!
Old Jan 30, 2007 | 09:38 AM
MagnaniEG6's Avatar
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Go back to your crappy beer and cheese. This isn't a WI thread.</TD></TR></TABLE>
lol go bears!!!!
Modified by Spoolin8 at 12:48 PM 1/30/2007
Old Jan 30, 2007 | 09:40 AM
Change's Avatar
Default Re: (MagnaniEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
lol go bears!!!! Look for me on ebay selling me as a date for the superbowl lol</TD></TR></TABLE>
Just dont look for you at my house buying my car or returning my PMs.
Old Jan 30, 2007 | 10:03 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (EFection)
bears
Old Jan 30, 2007 | 10:09 AM
freaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akiraboy &raquo;</TD></TR><TR><TD CLASS="quote">for sale
88hf
97 eclipse gsx
b16 head
b18a block
d16a6 head
d16z6 head
14b disassembled
wanted
all this ish gone</TD></TR></TABLE>
97 GSX?
Bears win.....thats cute.
Old Jan 30, 2007 | 10:18 AM
amthompson's Avatar
ONE DAY LEFT: http://cgi.ebay.com/ebaymotors...d=1,1
ALSO ON EBAY: http://cgi.ebay.com/ebaymotors...d=1,1
FOR SALE: $100 OBO / Interesting trades Considered:
Complete 96-00 Y8 Intake Manifold with throttle body, all sensors, etc. (manual trans)
Shoot me some IMs
Old Jan 30, 2007 | 11:28 AM
AlienKrOZ's Avatar
Default Re: (amthompson)
anyone know how to reprogram an immobilize key? i want to purchase 2 keys on ebay with the transponder for my 01 Infiniti but the dealer wont program my key unless if it's an oem key. if anyone knows how to do these hit me up on how much you want to charge. BTW I have 2 keys to get programmed
Old Jan 30, 2007 | 11:35 AM
Change's Avatar
Default Re: (AlienKrOZ)
1993 civic SI $2000OBO.
http://www.hondamarketplace.co...63939
Old Jan 30, 2007 | 11:59 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how to reprogram an immobilize key? i want to purchase 2 keys on ebay with the transponder for my 01 Infiniti but the dealer wont program my key unless if it's an oem key. if anyone knows how to do these hit me up on how much you want to charge. BTW I have 2 keys to get programmed</TD></TR></TABLE>I work for mitsubishi and our keys can't be programmed without a dealership scan tool. So you might be stuck.
Old Jan 30, 2007 | 12:14 PM
d16rice's Avatar
Default WTB/WTT
I'm looking for the following parts:
96-00 Civic EX catalytic converter (in mint condition)
96-00 Civic front spring w/ 2"-2.5" drop (name brand, not eBay)
96-00 Civic D-series rear manual transmission mount (the one that bolts to the subframe)
99-00 Civic Si rear sway bar w/end-links and brackets
94-01 Integra rear sway bar w/end-links, brackets and control-arms
I'm looking to buy those parts locally, or better yet, trade those parts for something I have in my for sale list below.
If trading spring, I have...
a set of front Tokico 1.5" springs and a set of OEM front springs
If you have complete Integra sway bar/control arm set up, I have...
a set of lightly used EK megan racing control arms
Old Jan 30, 2007 | 12:50 PM
MagnaniEG6's Avatar
bump for frank a really cool guy!!! and even cooler wagon
Old Jan 30, 2007 | 01:08 PM
MagnaniEG6's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, Feb 2007 <~Bears 2k7 Superbowl Champions~> (MagnaniEG6)
my friend is looking for b-serious motor mounts I think someone was selling some. Also he is looking for cable tranny LS
Old Jan 30, 2007 | 01:12 PM
BJOnewiper's Avatar
See signature
Buy a 240
See signature
Old Jan 30, 2007 | 01:29 PM
RapeV-8's Avatar
f/s 91 white crx hf w/ full DA brakes, little rust on the quaters, painted interior, ebay coil over, NOT RUNNING
OBO
Old Jan 30, 2007 | 01:42 PM
theinfamouskonrad's Avatar
Default Re: (igotcrx)
FS- Updated today!
FS....
4 wire o2 sensor-$20
'95 Gsr power steering pump with brackets-$40 (sold)
99-00 B16 SI power steering pump with brackets-$40 (still available)
Both in perfect working condition.
b-series hydro halfshaft-$30(sold)
b-series cable halfshaft-$30(still available)
b-series hydro drivers side axle-$25
2 b-series passengers side axles (need boots)-$10
Bosch 044 external pump. Comes with bracket and -6an fittings. Has less then 1500 miles on it. Mint cond. $175 picked up or $190 shipped.
RCI 5 gallon fuel cell. part # rci-2050D. You can use either the -8an lines or i'll include a set of -6an fittings. I also have about 20ft. of -6an russell's steel braided lines and an external fuel filter-offer
Selling my fully built b20-v motor. Motor made 549 whp 343 torque at 24psi while peeling out on 4th on the dyno.
Bottom end
'00 b20z2 usdm block
RS machine sleeved 84.5mm
Micropolished Honda crank, all new Honda main/rod bearings, honda thrust washers
Crower 4340 steel Billet rods
JE 9:1 pistons
Block was also hot tanked, and main journals were align honed.
Exedy twin disc clutch for 92+ b-series
head
92 Jdm b16a head
Intake ports were mildly port/polished by DH-racing as well as 5 angle valve job
Ferrea stainless valves
all new Oem honda valve seals
supertech springs/retainers
Cometic head gasket
Golden eagle head studs
Edelbrock victorX manifold
Mr. Gasket fuel rail
68mm billet throttle body
Type r Camshafts with Hayame cam gears.
Motor was built by Mike at Extreme parts in august. Car was tuned on S300 Hondata by Dave at Whipfactory. Motor has less then 3000miles on it. I have all receipts for the motor etc.etc. Motor does not smoke, it has 185compression across the board. Great oil pressure. Only reason i'm selling it is because i wanna do something different in my crx for next year *hint k-series. This engine is basically bullet proof (with the right tuning of course) Price is $4500 with twin disc or $3800 without! What a steal! Motor costed me $10,000+ if your planning on going all out for next year this will save you a lot of $. I did have pictures of the motor getting assembled etc. but i lost them when my computer crashed pm me if interested or if you would like to check it out in person. Located in Milwaukee, WI.
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 obo well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
CNC Reverse throw clutch pedal with master cylinder- For all you guys that want to convert your car to true hydrolic this is what you need. All you do is just run your -3an line straight to your clutch slave cylinder-$70
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $450
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
'92 JDM b16a engine is for sale. Bone stock has 65K on it!! Runs great, doesn't burn any oil etc. Come check it out before you buy! Will sell the everything except the tranny. $800 with ecu and dizzy, $700 without the dizzy and ecu.
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something -$25
more random junk...
Stealth style GSR intake manifold. Inside of it has been port/polished-$30
ecu's-...
obd0 88 Pm6-$10
obd0 91 pm5-$10
obd0 91 pm9-$10
obd0 91 pm9-$10
Tons of miscellanious EF parts, headlights, tail-lights, corner lights, cluster, resistor boxes, etc. etc. Ask me chances are i have it. I'm too lazy to take more pics. Selling for dirt cheap.
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
88-91 Civic/Crx steering column with tilt-$20
b-series upper and lower alternator brackets-$20
7/8" civic/crx brake master cylinder-$10
b-series hydro slave cylinder-$10
1 wire o2 sensor-$5
(2) b-series rear T brackets from 99-00 si-$30 each
(2) resistor boxes-$10 each
b-series fuel rail-$10
b-series fuel regulator-$5
90-93 DA integra hubs-$15
92-95 Civic front shock forks-$15
(2) lower b-series power steering brackets-$5 each
88-91 Civic/Crx radiator fan-$10
94+ integra radiator fan-$10
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Also for sale...
MINT cf hood for 96-98 civic-$200
Anyone interested in any parts PM me
Modified by theinfamouskonrad at 1:56 PM 2/4/2007
