When i hit vtec my car smokes...
im not losing oil or water....its not alot of smoke justa little, u can only really notice it if im not moving...whats the deal? should i just give her a tune up, she needs it lolz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taimaishui14 »</TD></TR><TR><TD CLASS="quote">how do you notice it when your not moving? VTEC only works when its in gear, VTEC doesnt engage in neutral.</TD></TR></TABLE>
haha. what is your car/motor/ mods? are you running chipped ecu. might be rich
Well then i guess it smokes a little at high rpms. no im a stock d16z6 with 112k miles, with a aem dry filter short ram intake....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyc »</TD></TR><TR><TD CLASS="quote">to bad it says 112k miles!!!! and he said he noticed it when hes not really moving</TD></TR></TABLE>
Ooops. Could be rings, valve stem seals, coolent, etc. There are multiple possibiites. We'd need more info to help.
Yes, just look at the color of the smoke. Mine does not do it in neutral but I do get some at vtec but it's a b series with hondata so it could be rich...
If it's doing it in neutral, try getting the color, or what it smells like (don't kill yourself
). If you think it's rings, try a compression/leakdown test.
If it's not worth it, just toss it and throw a swap in
It's up to you. There are a lot of tests out there to try to find your problem though, you just need more symptoms.
). If you think it's rings, try a compression/leakdown test.If it's not worth it, just toss it and throw a swap in
