d16z6 tranny?????
Old Jan 29, 2007 | 07:58 PM
legron_m's Avatar
Default d16z6 tranny?????
i know about the fast that ef's are cable and eg's are hydro, but my question is will the z6 tranny fit into an ef? and with what axles? thanks...i tried to search but i didnt find any satisfying answers
Old Jan 29, 2007 | 08:00 PM
dr_latino999's Avatar
Default Re: d16z6 tranny????? (legron_m)
Well it'd fit no problem, and you could you use your stock axles to the best of my knowledge. The problems come with the deletion of your front torque mount and the relocation of your rear mount bracket and passenger side mount, not to mention the hydraulic activation mechanism.
Old Jan 29, 2007 | 10:01 PM
Mista Bone's Avatar
D Tranny Guru
after replacing the shitty 4g diff pin, both tranny are equal in strength, but the nod goes to the 4g DX/Si 4th gear.
No need for a changeover.
Old Jan 30, 2007 | 05:45 AM
legron_m's Avatar
Default Re: (Mista Bone)
i wouldnt mind running a 4th gen si tranny but i just bought a d16z6 and tranny for 200 bucks and would not like to spend anymore money than i would have to since i am doing this project on a very tight budget.....thanks
Old Jan 30, 2007 | 06:29 AM
Default Re: (legron_m)
Well you are going to spend a nice chunk of money in custom fabrication (design isn't cheap)
Old Jan 30, 2007 | 10:21 AM
legron_m's Avatar
Default Re: (dr_latino999)
i am capable in doing the fabricating myself, my main concern is which axles will work, i am not sure if the splines are the same between ef's and eg's
Iloveyourhonda92
Jul 15, 2008 12:39 PM
onesikgsr
Jan 29, 2008 06:09 AM
M.A.R.C.
Jun 4, 2007 11:39 AM
Db1 Supreme
Mar 5, 2005 02:37 PM
Daisysi
Jan 29, 2004 06:01 AM
