i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ?
Old Jan 29, 2007 | 06:50 PM
DJNauTicz's Avatar
Default i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ?
i want to put more torque in my motor..
either all motor work..or..turbo charge..which one is better?? for it...
and the part's i should get..to put more torque into my ride..give me some info.thanks
Old Jan 29, 2007 | 06:58 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (DJNauTicz)
boost i can do this all day
Old Jan 29, 2007 | 07:03 PM
EJgsr's Avatar
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (Throwdown)
https://honda-tech.com/zerosearch
Old Jan 29, 2007 | 07:06 PM
MonkeyBoy668's Avatar
Well, there's always...
Old Jan 29, 2007 | 08:36 PM
Ruben19's Avatar
ls-vtec turbo
or high compression ls-vtec with cams and more ****.
im going turbo soon
Old Jan 29, 2007 | 09:17 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (Ruben19)
higer compression
Old Jan 29, 2007 | 09:27 PM
fmrprojects's Avatar
Default Re: (spock_rocker)
all motor is gonna cost you more. boost will get you better hp and tq #s. but if you put a 200hp all motor vs a 200hp turbo motor, the all motor will win. its all in your budget. me i would say all motor, but to answer your question, turbo will give you the more torque
Old Jan 29, 2007 | 10:03 PM
PACMAN8's Avatar
TURBOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO dont spent your money on all motor.
Old Jan 29, 2007 | 10:07 PM
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (PACMAN8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACMAN8 &raquo;</TD></TR><TR><TD CLASS="quote">TURBOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOO dont spent your money on all motor.</TD></TR></TABLE>
what do you have buddy. i bet you my all motor hatch can whoop on whatever car you got
Old Jan 29, 2007 | 10:28 PM
blinx9900's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">if you put a 200hp all motor vs a 200hp turbo motor, the all motor will win. </TD></TR></TABLE>
thats about the dumbest thing i ever heard, care to explain?
Old Jan 29, 2007 | 10:33 PM
Default Re: (blinx9900)
the all motor car will run better times than the turbo car. post this in the all motor and turbo forum and you will find out. i ran a 12.4 in my all motor street hatch. my friend had a 220 hp ls turbo set up in a hatch that only ran best of 12.8 on slicks. so explain that. and dont say its the driver cause hes a good driver. been racing for 4 yrs.
Old Jan 29, 2007 | 10:35 PM
same goes for like a 300hp all motor setup in a hatch, it will run low 11s. but a 300hp turbo setup will run mid 11s
Old Jan 31, 2007 | 07:27 PM
PACMAN8's Avatar
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (fmrprojects)
how much you wanna bet you cant beat me with your all motor BUDDY.i don't have time for this stupid argument + plus you don't even know what i have why would you say something like that.THERE IS ALOT YOU DON'T KNOW.i do have a all motor car which is my daily drive.takes me from point A 2 point B.full tank gas i drive 84-90 miles on 440CC injectors.and my turbo car which i blew last month is almost done.FULL RACE STAGE 4.just drop this **** now cuz i don't have time for this.but let me tell u one more thing i bet u my all motor will take ur car.
Old Jan 31, 2007 | 07:31 PM
turbociviccoupe's Avatar
wow people are getting hostile here on honda-tech.
but i can vouch for fmrprojects...seen his car run at cmi...fast all motor
Old Jan 31, 2007 | 07:42 PM
Hemix's Avatar
Woohoo! Forum racing! Who's got the bigger *****?
Old Jan 31, 2007 | 07:46 PM
Eran's Avatar
HT White Ops
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (Hemix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hemix &raquo;</TD></TR><TR><TD CLASS="quote">\Who's got the bigger *****?</TD></TR></TABLE>
I do.
Old Jan 31, 2007 | 09:09 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">the all motor car will run better times than the turbo car. post this in the all motor and turbo forum and you will find out. i ran a 12.4 in my all motor street hatch. my friend had a 220 hp ls turbo set up in a hatch that only ran best of 12.8 on slicks. so explain that. and dont say its the driver cause hes a good driver. been racing for 4 yrs.</TD></TR></TABLE>
first im not posting anything just cause you said to, second i cant explain anything without ALL the details on each of your set ups, includeing vehicle weight, driver weight, cars used, engines used, trannys used, tires used, spring ratees, full suspension set up, tire pressure, altitude, air temp, and i need to see a dyno graph showing hp and tq outputs, among a million other things, dont just say oh well he did and then i did, it dosent work that way. power is power, it dosent matter how you make it. and lets not forget about tq here.
to the op, aside from stroking, ive seen crane cams add 20wheel tq to an ls motor, i believe they were stage II crane cams. which ever is there "street cam"
Old Jan 31, 2007 | 09:29 PM
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (Eran)
its an awesome pissing contest we have isn't ladies?! point being he has an LS engine, with the right amount of money and parts he can make 190whp NA.. which i think it penty. TQ numbers in the 140s..
Old Jan 31, 2007 | 10:02 PM
Hemix's Avatar
Default Re: i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ? (spock_rocker)
Why would you want more than 200hp to the wheels of a front wheel drive car anyways? Oh ya, drag racing.
Old Feb 1, 2007 | 04:48 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
I love a LS. I had JDM ITR pistons, shotpeened rods with arp rod bolts, Ported 94' LS head with crower springs and retainers, crower 404 cams, skunk 2 IM, DC 4-2-1 hedder, running uber data. PLus other random stuff b16 tranny, clutch and fly wheel, ect. First pull untened I only made 151 hp and like 120+ ftlb. But after tuning it ended up making 183hp and 147ftLB. I'll try to dig out the dyno sheet. It had the broadest torque range of any motor I have ever built. Good luck with your build bro. I hope it turns out great.
Old Feb 1, 2007 | 05:39 PM
DJNauTicz's Avatar
argee with this..i dont need anything more then like 200hp..
but around 200 is fine for a daily drive..so any idea of what i should put in my ride?
all motor i dont mind turbo i dont mind but i just want to know which one is the best idea,,,i like turbo.only reason because of the blow off,other then that..i dont really into turbo..so more info beside hating..peoplse..
i just want info not hate.
Old Feb 2, 2007 | 04:25 PM
THE GUY's Avatar
Honestly for what I spent to get the amount of power that I did you could boost your car. And doing that make more power. My car was great fun with that motor, but it was a pain to start on cold days. And those cams had such a aggressive profile I had to idle it up higher to keep it from stalling. It's really just a personal preference. I love allmotor but you can make great power cheaper with a small turbo kit.
Old Feb 2, 2007 | 08:17 PM
Mr.Eg6's Avatar
ALLMOTOR "FTW"
Old Feb 2, 2007 | 09:19 PM
smileycvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
thats about the dumbest thing i ever heard, care to explain?</TD></TR></TABLE>
Traction. Its really true. You also dont have to worry about turbo lag.
To the OP Buy a truck, and welcome to owning a Honda.
Old Feb 2, 2007 | 09:32 PM
blinx9900's Avatar
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">Traction. Its really true. You also dont have to worry about turbo lag.
with proper tires/suspension and turbo sizing none of that is an issue, any car will have problems if not set up correctly, that is a bad answer. and turbo lag isent an issue becuase you never fall out of boost between ***** AND a boosted car generally has a wider powerband and more tq. still waiting for a resonable answer for such a bold statement.
highflyinhonda
Sep 29, 2005 09:03 PM
UsDm_Junky
Sep 12, 2005 02:02 PM
civicmatt
10
Sep 2, 2002 07:25 PM
Slick GS-R
Mar 22, 2002 04:12 PM
Aar99GSR
Mar 20, 2002 01:31 PM
