Bulb in dash blown.. How do I fix it ?
The bulbs or bulb behind my A/C control (the slider) seems to be going out periodically or going dim... How do I access that bulb to get the number and change it ?
Take a screwdriver (cover it with some cloth) and pry the Hazard and Defrost switch, then remove the 2 screws behind it. Carefully remove the entire A/C console.. it will pull about 3-5 inches out.
Then disconnect all the plugs in the rear, and the wire lever for the "hot-cold" postion thing. After that the whole console comes out. Im not sure where you can get the bulbs besides the dealer tho.
Good luck
Good luck
I was just trying to do the same thing. I've pulled the A/C console out a few inches but I cant get to any of the plugs or the wire lever to disconnect them and get the console out all the way. Does anyone have any tips?
thanks.
thanks.
i got a question concerning the ac console. do u know the pictures on the button where u choose where u want the air to blow, does it light up when u turn on the headlight. on my friend civic its lights up but on my teg it doesn't.
