weird injector question
ok heres some quick background on the situation , i bought a 99 si with a drag 3 turbo kit on it , it was a haggered piece of crap before I got ahold of it , so basically im going through the whole car and redoing everything , but the problem is I have no clue what injectors this car is running , they couldnt be too big because it was running on a fmu (thats going to be gone ) I know they are not stock becuase the wires have been cut and resolderd for new plugs , there is not a resistor box , so they would have to be a saturated injector , only thing on the injector i could fine is that they were made by keihin , if im not mistaken those were only in accords and preludes , but the thing that makes no sense to me is the fact the plugs were changed , if they were obd1 they would be p&h not saturated so there would have to be a resistor box . and if they were obd2 they would be saturated and the plugs would have been the same right? so Im not sure if theese are obd1 or obd2 plugs i eclosed a pic , im clueless so if anyone has any opinions some imput would be great need to know what injector size is so i can have a base map made ,thanks to anyone that reads this
I have keihin injectors on my JDM B16 Sir 2, so chances are that they could be JDM unless some usdm motors used to come with them in OBD 1. Cause obviously all the newer stuff is IPT. But in any case they're probably 240cc's unless they're prelude injectors which i believe are bigger (290) maybe, but i may be wrong. In any case you don't care cause you need bigger ones anyway
are those obd1 plugs or obd2 , I know ill need bigger injectors im going to run somwhere around a 700 cc injector but im having a basemap made in a chiped p28 for low boost to get to the dyno and hour and a half away , and to have that base map made i need to figure out what injectors theese are
mynameisrand
Jun 2, 2009 08:31 AM
crex23
May 24, 2005 05:57 AM
