D16 BUILD
have been doing some soul searching and i have decided that i would like to turbo my D16Z6 wich has 243K on it and i would like to get it around 200-250 horse power and keep a daily driver. To achive this goal i no that i will probaly have to replace the rods and pistons. i have done a but of research and i kinda have have an idea what do to do with it. i would like to no what rods. pistons and a turbo kit that would work and be sorta kindof cost efeective around $3500 or even less. ya thanks
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
The key to planning a good setup is choosing the right parts to upgrade and concentrating on the areas which need to be Upgraded to help increase strength for a turbo setup.
Im not sure if you are looking at $3500 just for the engine build or with the turbo setup but, here's what I suggest.
Bottom end:
Pistons 75.5mm 9:1 compression
Rods: Eagle D16
OEM rod bearings and thrust washers
OEM Oil Pump
OEM bottom end gasket set
Fresh Bore. Hone, hot tank, deck
Cylinder head:
Recondition the head with a new 3 angle valve job and resurface
Install new valve seals
upgrade the valvesprings and retainers
keep stock valves if they are still good, no need to upgrade these.
New head gasket
Timing belt
ARP head studs
Water pump
This setup will cost about $3400.00
You strengtened the block internals and put new parts so you're good in that department. And the cylinder head is refreshed so its like new. Valve springs are new and stronger than stock so it can help prevent valve float and be able to withstand the higher rpm boost.
Other things you can do but is not necessary since you arent planning to go over 300hp, is to sleeve the block and port the cylinder head. You can do without those if not planning to go all out with this engine.
any questions feel free to PM me.
Bottom end:
Rods: Eagle D16
OEM Oil Pump
Cylinder head:
New head gasket
Timing belt
ARP head studs
Water pump
montanacivic
Dec 29, 2018 04:16 AM
