clutch pedal free play adjustment ( anyone know how? )
Old Jan 29, 2007 | 05:15 PM
eklum's Avatar
Default clutch pedal free play adjustment ( anyone know how? )
after replacing my flywheel and clutch i noticed the let off points wayy lower ( idk if thats normal or not)
but i was told to adjust the free play of the pedal could any one here tell me how to do so?
thanks
Old Jan 29, 2007 | 09:52 PM
eklum's Avatar
bump
Old Jan 29, 2007 | 09:53 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: clutch pedal free play adjustment (EKlum)
myself, I've never messed with it.
I've likely had more used clutch combos and I KNOW FOR FACT more trannys in my car than anyone else.
Dying/leaking clutch master cylinder, I just top off the fluid every 5k mile oil change.
Old Jan 30, 2007 | 08:51 AM
kreush33's Avatar
Default Re: clutch pedal free play adjustment (Mista Bone)
Reading the manual usually helps in these situations.
Old Jan 30, 2007 | 08:55 AM
Luserkid's Avatar
Default Re: clutch pedal free play adjustment (kreush33)
Did you bleed the clutch before you messed with the adjustment rod? You shouldnt have to mess with that.
Old Jan 30, 2007 | 09:02 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
look at the pedal assembly. it is very straight forward. if you cannot figure it out by looking at it, then you should not be changing making any adjustments...
Old Jan 30, 2007 | 05:36 PM
eklum's Avatar
actually that helped me out alot.. but im still not likeing the spongey feeling it gives it seems to be leaking a little bit of fluid from the m/c maybe its time for a new master cylinder
after 250xxxmiles its time im sure.
K3VL4R
Nov 18, 2012 03:39 PM
Lude@Heart
Transmission & Drivetrain
Jan 12, 2012 12:45 PM
Boostin_GSR
Jun 3, 2007 11:34 AM
MrSmith
Sep 28, 2001 08:30 PM
