OBD1 p72 in my gsr swapped si..best ecu to run with?
Old Jan 29, 2007 | 10:43 AM
Mikes2000civicsi's Avatar
Default OBD1 p72 in my gsr swapped si..best ecu to run with?
hey guys,my car when i bought came with a obd1 p72 with my b18c1..is this best ecu i can run for the money?thanks
Old Jan 29, 2007 | 11:16 AM
doood's Avatar
been there done that
Default Re: OBD1 p72 in my gsr swapped si..best ecu to run with? (Mikes2000civicsi)
if it's stock, yes
Old Jan 30, 2007 | 06:52 AM
Default Re: OBD1 p72 in my gsr swapped si..best ecu to run with? (doood)
when its gets modded up...pistons cams...whats a better ecu then...thx
Old Jan 30, 2007 | 07:04 AM
Luserkid's Avatar
A dyno tuned ecu. As long as its stock or I/H/E is the p72.
Old Jan 30, 2007 | 07:14 AM
BlakeJ53's Avatar
chipped p28 so you dont half to wire in all that extra ****.
Old Jan 30, 2007 | 07:17 AM
kay_animation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">when its gets modded up...pistons cams...whats a better ecu then...thx</TD></TR></TABLE>
When you are doing simple stuff like I/H/E, then the stock ecu would be better for ya.
You could probably go to a tunable ecu but you wouldn't get too much gains.
But if you do things that need tuning like cams, cam gears, itb's, engine work (upping compression stuff), then you'll need an ecu to tune for that.
Chrome seems good for saving money, Hondata s200 is what I'm running now, really like it. Best thing to do... if you wanna get tuned, find a tuner that is really good, see what they use, and get that. You usually have to work with the tuner cause you want them to get the best results for you setup and they may be more at home with a certain playing field if that helps
Old Jan 30, 2007 | 11:42 AM
doood's Avatar
since your ecu is already obd1 just have it chipped and tuned at the point you need something like that
Civic483973
Jul 30, 2010 09:26 AM
DOHC Kid
May 27, 2008 05:41 PM
HAccord96
Dec 10, 2003 12:23 PM
NuclearB18B
Sep 19, 2003 04:15 PM
