Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
HONDA Factory OIL good or BAD?
Old Jan 29, 2007 | 10:41 AM
Scarface1's Avatar
Default HONDA Factory OIL good or BAD?
What is the difference between Honda factory oil and aftermarket oil brands?
I have a 06 civic ex (r18 1.8L)
Should I change oil brands or stay with Honda? Any input would HELP.
Old Jan 29, 2007 | 11:02 AM
TRE_'s Avatar
Default Re: HONDA Factory OIL good or BAD? (Scarface1)
Provided the oil has API(American petroleum institute) approval and its the correct weight it doesn't really matter what "brand name" it is.
The bottle should have a similar looking seal/star on it if its API approved:
Old Jan 29, 2007 | 01:00 PM
liketofry's Avatar
When I go to the dealer for oil changes they use the Honda factory oil, haven't had any problems, but like TRE says it does not really matter
Old Jan 29, 2007 | 01:09 PM
TRE_'s Avatar
Default Re: HONDA Factory OIL good or BAD? (liketofry)
Actually in SOME dealerships they dont even use "HONDA" oil... they buy cheaper drums of oil and use them in the cars in service.
Old Jan 29, 2007 | 01:52 PM
RICO_'s Avatar
NO MERCY!
Default Re: HONDA Factory OIL good or BAD? (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">Actually in SOME dealerships they dont even use "HONDA" oil... they buy cheaper drums of oil and use them in the cars in service. </TD></TR></TABLE>
That's EXACTLY why I DON'T go to the dealership for oil changes!
Old Jan 29, 2007 | 01:57 PM
liketofry's Avatar
Such evil....
Thanks for the heads-up.
Old Jan 29, 2007 | 02:20 PM
Scarface1's Avatar
So i guess its better for myself to do it? Any way one could tell if the dealership is ripping one off?
Old Jan 29, 2007 | 02:21 PM
Fonz's Avatar
Honda Oil is I believe just Exxon oil.
Modified by Fonz at 6:32 PM 1/29/2007
Old Jan 29, 2007 | 02:40 PM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scarface1 &raquo;</TD></TR><TR><TD CLASS="quote">
So i guess its better for myself to do it? Any way one could tell if the dealership is ripping one off? </TD></TR></TABLE>
It's more expensive if you do it but I think you'll be better off. Mobil1 synthetic is really good stuff, but is probably twice as much as "honda" oil.
Of course the dealership will recommend THEIR stuff, it's how they make more money, but for little maintenance like oil changes you can go somewhere else or do it yourself.
Old Jan 29, 2007 | 02:45 PM
Scarface1's Avatar
Default Re: HONDA Factory OIL good or BAD? (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
Of course the dealership will recommend THEIR stuff, it's how they make more money, but for little maintenance like oil changes you can go somewhere else or do it yourself.</TD></TR></TABLE>
Hey, thanks man. got good insight. I'll probably take it to a local tuner shop around my area. Once again thanks for the info.
Old Jan 29, 2007 | 02:49 PM
RICO_'s Avatar
NO MERCY!
Foget aboouut it......
Old Jan 29, 2007 | 03:55 PM
Tadehi's Avatar
Schumacher '10 WDC
Actually, and Tre_ correct me if I am wrong but I think he said somewhere that Honda Oil is actually made by Mobil-1. If I am wrong Please let me know Tre_
Old Jan 29, 2007 | 04:21 PM
redej878's Avatar
Default Re: HONDA Factory OIL good or BAD? (Tadehi)
I am an express tech at a dealership. Honda uses mobil one as there oil provider. So when you buy a quart of Honda Oil you are buying mobil one.
Old Jan 29, 2007 | 04:33 PM
skittle06's Avatar
None of the ones here use Honda oil or Honda's MTF. For the most part, they all use either Amsoil, Mobil 1 or GM fluid. They don't even wait, they just swap oil upon delivery. No problems so far.
Old Jan 29, 2007 | 04:42 PM
M1K3's Avatar
my hondadealer uses penzoil
Old Jan 29, 2007 | 04:46 PM
honda06si's Avatar
Default Re: HONDA Factory OIL good or BAD? (redej878)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redej878 &raquo;</TD></TR><TR><TD CLASS="quote">I am an express tech at a dealership. Honda uses mobil one as there oil provider. So when you buy a quart of Honda Oil you are buying mobil one.</TD></TR></TABLE>
yea thats your dealership. but you dont work at all of them
Old Jan 29, 2007 | 04:47 PM
RICO_'s Avatar
NO MERCY!
Default Re: HONDA Factory OIL good or BAD? (honda06si)
So why are the oil changes so cheap then? 30 bucks for FULL synthetic oil change?
Isn't Mobil1 synthetic like 6 bucks a quart, plus the labor, and filter.??
Comes to around 55-60 bucks at Jiffy Lube.
So i take it the oil used varies from dealer to dealer??
Old Jan 29, 2007 | 04:49 PM
redej878's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda06si &raquo;</TD></TR><TR><TD CLASS="quote">but you dont work at all of them</TD></TR></TABLE>
Thanks for letting me know that.....
Old Jan 29, 2007 | 05:05 PM
honda06si's Avatar
Thanks for letting me know that.....</TD></TR></TABLE>
no problem
i was just trying to say that every dealership uses diffrent oil. it would be great if all of them were like yours and used quality oil but some of them would rather save some $
Old Jan 29, 2007 | 05:47 PM
redej878's Avatar
no problem
i was just trying to say that every dealership uses diffrent oil. it would be great if all of them were like yours and used quality oil but some of them would rather save some $</TD></TR></TABLE>
Yeah I see what your saying.
Old Jan 29, 2007 | 06:08 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tadehi &raquo;</TD></TR><TR><TD CLASS="quote">Actually, and Tre_ correct me if I am wrong but I think he said somewhere that Honda Oil is actually made by Mobil-1. If I am wrong Please let me know Tre_ </TD></TR></TABLE>
Exxon Mobil manufactures a specific oil blend for Honda Motor Co. but it is NOT a synthetic based oil.
A lot of dealerships will buy cheaper oil that is still API certified and use that during a service. Honestly buying oil in bulk from Napa (or an equivalent store) is MUCH cheaper than buying it directly through a local Honda oil distributor.
Old Jan 29, 2007 | 06:44 PM
roadawg's Avatar
Honda doesn't refine its own oil, they use the same oil everyone else is using.
They just slap their Honda logo on the bottle and call it a day.
And you better believe on top of that fact also, that the oil Honda uses is engineered to properly lubricate the motors they put the oil in.
Old Jan 30, 2007 | 08:59 AM
IT GUY's Avatar
A few dealerships around here even have huge castrol banners hanging from their service center signs.
Old Jan 30, 2007 | 03:38 PM
kroze's Avatar
Jiffy lube is supposedly the best you can get for your car. Drop your car off at jiffy lube and you're set.
Old Jan 30, 2007 | 03:41 PM
Scarface1's Avatar
Default Re: HONDA Factory OIL good or BAD? (kroze)
I have heard that jiffy lube uses recycled oil. Is that True?
