Squeaking noise?
Old Jan 29, 2007 | 07:33 AM
EvenStar's Avatar
Default Squeaking noise?
95 accord lx 80K miles.
Everytime I get in the morning ready to leave and warm up my car, there is always this squeaking noise coming from the engine bay. It usually stops after the 'jumping idle', but this time it kept on going. I popped the hood open and listen closely to where the noise is coming from. Sounds like the timing belt or alternator. But the sound did go away after I was driving. I can also see my engine physically shaking a little bit. Any ideas?
It also didnt look like the last owner did the major tune up yet at 90K miles and I believe he was treating this car like **** by not warming it up every morning and pushing hard on the brakes and gas.
Old Jan 29, 2007 | 08:02 AM
hondadude's Avatar
Default Re: Squeaking noise? (EvenStar)
When the noise is present squirt the inner Alt belt surface with brake clean or carb cleaner. If the noise shuts up try adding some more tension to the belt or replace it. Those belts need to be just about 'banjo string' tight.
Then about the 'jumping' idle; surging? Coolant full and block burped thru the 12mm bleed screw at the T-stat housing? FITV need adjusted?
Old Jan 29, 2007 | 08:43 AM
EvenStar's Avatar
Default Re: Squeaking noise? (hondadude)
is it better to replace the timing belt + water pump, etc. now at 80k miles? or should i wait?
Old Jan 29, 2007 | 07:33 PM
fleetw00d's Avatar
The squeaking is more likely to be the alternator/power steering/AC belts than the timing belt. If you're just trying to stop the squeaking, change those and make sure they are tight. Timing belt interval is 90,000, but you should also consider the age if is still the original (sure bets pistons smacking valves!). The alt/PS/AC belts are probably only $20, the timing belt is a $600 job at a dealer.
Old Jan 29, 2007 | 07:58 PM
Homesickelian's Avatar
Default Re: Squeaking noise? (fleetw00d)
Yeah, I'm not to sure how age would effect the life of a timing belt but I'd say take the car to 89,000 miles then switch it. I mainly agree with what fleetwood said.
Old Jan 29, 2007 | 09:59 PM
ZOOM AUTO PARTS N TIRES's Avatar
it definitely sound like your belts are just a little loose. tension the belt and you should be fine. if that doesn't work maybe its the bearing in your belt pulley. good luck.
Zumo
Feb 16, 2007 10:45 PM
d124g0n
Jul 21, 2005 06:29 PM
Speed_69
Jun 6, 2005 11:12 PM
AirWaveGT
Sep 12, 2004 07:33 PM
