Honda S2000 Honda S2000
s2000 faster with 17' wheels or faster 16' wheels?
Old Jan 29, 2007 | 03:34 AM
Mashka's Avatar
Default s2000 faster with 17' wheels or faster 16' wheels?
I don't know.. Please help me ...
Old Jan 29, 2007 | 04:35 AM
cmdr430's Avatar
Default Re: s2000 faster with 17' wheels or faster 16' wheels? (Mashka)
are you comparing stock wheels or aftermarket wheels?
aftermarket can potentially make a difference depending on how light they are....i.e. rotational weight
Old Jan 29, 2007 | 05:07 AM
Creizai's Avatar
Default Re: s2000 faster with 17' wheels or faster 16' wheels? (cmdr430)
Only in track lap situations, but thats comparing both wheels weigh the same and are wearing the same exact tires.
Old Jan 29, 2007 | 05:33 AM
madlion's Avatar
Default Re: s2000 faster with 17' wheels or faster 16' wheels? (Creizai)
Assuming the wheels weigh the same. the tire sizes are the same. It all depends on the driver. top end will be better with 17s. acceleration will be better with 16s. this is very dependent on the driver. there will be more surface area on the ground with 17s. this effects braking and everything else. but the 16s have less of a rotation will spin quicker. a lot of it has to do with how much power you are putting down on the ground. obviously not a lot of power 16s will fair you better. people usually opt for 16s because they arent as heavy. but i am not considering that in this post. you have to consider lots of things. like where you live. i live in pot hole land. you have to drop a car more that is on 16s to get rid of the wheel gap depending on your tire size. i think the car looks good with 17s. you could do the 16s in the front 17s in the back for extra downforce
Old Jan 29, 2007 | 06:56 AM
Mashka's Avatar
Default Re: s2000 faster with 17' wheels or faster 16' wheels? (madlion)
Thank you!
I am intresting drag time best with 16' or 17'..
combination:
Front ---- Rear ---- Wheel
Wheel ---- Wheel ---- size
16'x7 (Oem) ---- 16'x7.5 ---- 225x50
16'x7 (Oem) ---- 16'x7.5 ---- 225x40
16'x7 (Oem) ---- 17'x7.5 ---- 225x50
16'x7 (Oem) ---- 17'x7.5 ---- 225x40
17'x7 (Oem) ---- 17'x7.5 ---- 225x50
17'x7 (Oem) ---- 17'x7.5 ---- 225x40
experienced?
track autobahn...
oem wheel weight?
Old Jan 29, 2007 | 07:39 AM
Dave_B's Avatar
I think it's the OD and weight that make the most difference. Meaning OD of rim and tire, not just rim.
Old Jan 29, 2007 | 10:10 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Dave_B)
best motoring did a test of the 2 OEM sizes against eachother...AP1 vs AP2...
both had close times.. they then put the AP2's on the AP1 and cut a 1.5 sec faster lap time each time
Old Jan 29, 2007 | 12:42 PM
ricepicker's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">best motoring did a test of the 2 OEM sizes against eachother...AP1 vs AP2...
both had close times.. they then put the AP2's on the AP1 and cut a 1.5 sec faster lap time each time</TD></TR></TABLE>
That was also due to a wider tire.
Wider tires will allow you to grip more through corners and allow faster cornering speeds.
But like Madlion posted. It really depends on the situation
Drag racing between the 17's and 16's. The 17's have close to the same rolling diameter. So there are really only 2 factors left. the width and the weight of the 16's and 17's. The 17's have a wider tire, so traction would be better, and I'm not sure about the weights of AP1 Vs AP2 wheels with tires. There is some conversion that converts rotating mass to dead weight theoretically.
Road racing I would choose the 17's over the 16's regardless of the weight difference. Wider tire &gt; Skinny tire
Old Jan 29, 2007 | 12:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">
Road racing I would choose the 17's over the 16's regardless of the weight difference. Wider tire &gt; Skinny tire</TD></TR></TABLE>
yes i know that....
Old Jan 29, 2007 | 01:33 PM
Francesco's Avatar
16'' and 17'' really isnt that drastic of a size difference compared to 16'' vs. 18''.
I understand the pros and cons of both when it comes to centrifical force and contact patch for wider tires. My vote will say its a drivers race. A car might be faster on 17's compared to 16's if the driver is more familure with the car and street/track.
For drag racing you want a smaller rim with large width.
Old Jan 29, 2007 | 04:06 PM
ricepicker's Avatar
yes i know that.... </TD></TR></TABLE>
Just makin' sure the OP knew that if he hadn't seen that Best motoring.
Old Jan 29, 2007 | 04:43 PM
Mr. Projekt's Avatar
* B A N N E D *
Just makin' sure the OP knew that if he hadn't seen that Best motoring. </TD></TR></TABLE>
There was a Best Motoring comparing the AP1 abd AP2 suspension/wheels, where the AP1 with AP2 wheels were .5 seconds faster than a stock AP1, and the AP2 with AP1 wheels was another .5 secs slower than the stock AP2.
Modified by Mr. Projekt at 10:04 AM 1/30/2007
Old Jan 30, 2007 | 06:18 AM
Mashka's Avatar
Thanks to all
Old Jan 30, 2007 | 07:47 AM
blanka98's Avatar
Default Re: (Mashka)
I myself use both AP1 and Ap2 wheels on my AP1. I feel that the AP1 wheels has a faster acceleration. That's what my butt dyno tells me
albayfz450
May 19, 2011 10:17 PM
DisturbedK24
Jun 4, 2008 07:27 PM
handa
May 15, 2006 03:37 PM
Paprika
47
Dec 7, 2004 04:27 PM
Black Sheep
Mar 4, 2002 12:14 PM
