This rattling sound is driving me nuts LOL.....
Old Jan 28, 2007 | 10:17 PM
chomorro's Avatar
Default This rattling sound is driving me nuts LOL.....98 Accord
I'm just ranting with this post i don't expect anyone to know what the hell is rattling
98 Accord. The rattle is coming from the driver side front somewhere and its driving me insane. I took it to a mechanic he told me it was my coil overs so i spent 800 bucks and got new springs, alignment, tires, everything. They put it on i still have this rattle. Im pissed so i go to another mechanic. He takes my car for a day and says its because im missing the plugs that fasten my fender lining on underneath. So i go to the dealer and spend like 40 bucks on these stupid plugs, i put them all on and the rattle is still there...... It happens when i go over a bump but not on the freeway only traveling around 20-30 mph and its pretty loud with no stereo on. So i jacked up my car i shook everything i could but no luck it all seems tight and secure even in under the hood.
So i know no one can help just by a description and im probably going to have to take it to another mechanic but they all just blame it on after market parts or they charge me a ton of money to find out what it is......
My question is, does anyone know of a way i can put my car on jack stands in the front yard and simulate hitting bumps so i can hear where the sound is coming from??? Maybe a peace of wood used as a lever that i jump up and down on would work HMMMMMMM. I'm just ranting with this post i don't expect anyone to know what the hell is rattling
UPDATE: i can feel slight movement in the clutch pedal, with it pressed all the way down in unison with the rattle. i also can hear the same rattle but almost silent from the passenger wheel area.
Modified by chomorro at 2:10 AM 1/30/2007
Old Jan 29, 2007 | 01:50 AM
K24xCM5's Avatar
Default Re: This rattling sound is driving me nuts LOL.....98 Accord (chomorro)
Hmm.. You should try shaking the door. Maybe there is a loose screw that fell off. It is probably causing the problem. If its not the door, let me know ill think of other things for you to check.
Old Jan 29, 2007 | 06:28 AM
Patman's Avatar
You don't have a bug deflector rattaling do you? I need to put new screws in mine, too lazy.
Old Jan 29, 2007 | 06:37 AM
Tech-Nics's Avatar
it could possibly be somthing with the down pipe. i had the same problem with my old integra and turned out to be the down pip twards the front near the CAT and it was rattling against those metal shields that cover the bottom of the car. between the top of the down pipe and the bottom of the car itself. im sure you know what im talking about...
Old Jan 29, 2007 | 10:27 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chomorro &raquo;</TD></TR><TR><TD CLASS="quote">My question is, does anyone know of a way i can put my car on jack stands in the front yard and simulate hitting bumps so i can hear where the sound is coming from???</TD></TR></TABLE>RAMPS.
With the front wheels up on ramps, the suspension is compressed to it's normal position. The shocks aren't extended all the way open. The lower control arms are in their normal position, etc...
If you're REALLY careful about how the car is positioned, you can get under & grab & shake things to your hearts content. You can shake the car so the suspension moves up & down in it's normal range of motion.
Be REAL picky about how the front wheels are centered in the ramps. Drive back down & fix it until you're happy. YOU are the one who'll be underneath if it falls off.
Set the handbrake and chock the rear wheels. Both wheels, 2 chocks on each.
Before you get underneath, grab the front bumper & shake it up & down as hard as you can. Just to test whether you can make the sound in the first place.
Old Jan 29, 2007 | 05:08 PM
chomorro's Avatar
Default Re: This rattling sound is driving me nuts LOL.....98 Accord (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">You don't have a bug deflector rattaling do you? I need to put new screws in mine, too lazy.</TD></TR></TABLE> Do you happen to have a pic of this piece??? I want to check this out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics &raquo;</TD></TR><TR><TD CLASS="quote">it could possibly be somthing with the down pipe. i had the same problem with my old integra and turned out to be the down pip twards the front near the CAT and it was rattling against those metal shields that cover the bottom of the car. between the top of the down pipe and the bottom of the car itself. im sure you know what im talking about...</TD></TR></TABLE> It sounds more like its coming from the fendor or maybe the wheel somehow. Today with the clutch all the way pressed down i could feel slight movement in unison with the rattle. Any ideas??<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">RAMPS.
</TD></TR></TABLE> I have a set of ramps but im afraid they might be to steep for my lowered car, and will tear off my bumper. Its worth a try anyways, i will do it this weekend if no one else has any other suggestions.
Old Jan 29, 2007 | 05:34 PM
361 accord's Avatar
my dumb *** accord is making the same noise, but its auto, im pretty sure its coming from the driver door cuz ittl rattle and when i push ion the door panel a little it will stop, so ithere probably a screw or something in there moving around
Old Jan 29, 2007 | 05:39 PM
chomorro's Avatar
Default Re: This rattling sound is driving me nuts LOL.....98 Accord (361accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361accord &raquo;</TD></TR><TR><TD CLASS="quote">my dumb *** accord is making the same noise, but its auto, im pretty sure its coming from the driver door cuz ittl rattle and when i push ion the door panel a little it will stop, so ithere probably a screw or something in there moving around</TD></TR></TABLE> Actually i do have that rattle lol, but that is a way different rattle, that one especially makes noise when the subs hit. Im not worried about that because i can barely hear it, but i know what your talking about
Old Jan 29, 2007 | 06:03 PM
WhiteOnRice's Avatar
Check motor mounts
Old Jan 29, 2007 | 06:20 PM
361 accord's Avatar
Default Re: (fizix_skate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">Check motor mounts</TD></TR></TABLE>
good idea, but HOW, do i just stare at them or what lol, is it gonna be totally obvious if its bad or what
Old Jan 29, 2007 | 06:30 PM
Put the car into gear (or park) without the ebrake on. Pop the hood and rock the car forward and back and watch all the mounts. If one makes noise or moves excessively, its probably junk. Good luck
Old Jan 29, 2007 | 08:16 PM
JimBlake's Avatar
Default Re: (361accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chomorro &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of ramps but im afraid they might be to steep for my lowered car, and will tear off my bumper.</TD></TR></TABLE>You might be able to put a couple pieces of wood (2x4?) down to extend the ramp making it shallower. My ramps have this funny pastic wedge you stick on it to extend the sloping part about 2x as long.
For that matter, maybe you only need to open the hood & push up & down on the fender. Listen from above, you may be able to pinpoint the sound without actually getting underneath.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361accord &raquo;</TD></TR><TR><TD CLASS="quote">good idea, but HOW, do i just stare at them or what lol, is it gonna be totally obvious if its bad or what</TD></TR></TABLE>You can also grab the valve cover & shake the engine around. Engine mounts usually make klunking sounds as the engine moves (getting on & off the gas). I imagine you wouldn't call it a 'rattle'. But maybe ???
Old Jan 29, 2007 | 08:30 PM
hondaccord's Avatar
Default Re: (JimBlake)
try rotating you tires, might not change, but worth a shot. are there any odd breaking sensations? lift the front tire, and tr to move it by hand back and forth, then up and down.
Old Jan 29, 2007 | 09:05 PM
chomorro's Avatar
Default Re: (hondaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord &raquo;</TD></TR><TR><TD CLASS="quote">try rotating you tires, might not change, but worth a shot. are there any odd breaking sensations? lift the front tire, and tr to move it by hand back and forth, then up and down.</TD></TR></TABLE>No odd breaking stuff, the tires are all new. I tried lifting the tire up and down but i cant budge it lol im not strong enough. Im going o try bouncing on it tomorrow if it stops raining. As far as motor mounts i will check it tomorrow but it doesnt make the sound at all when first accelerating only going over bumps.
Old Jan 30, 2007 | 03:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">Put the car into gear (or park) without the ebrake on. Pop the hood and rock the car forward and back and watch all the mounts. If one makes noise or moves excessively, its probably junk. Good luck</TD></TR></TABLE>
Did you try this?
Old Jan 30, 2007 | 04:52 PM
361 accord's Avatar
not yet here, ive got these sheets of plywood on the garge floor that are the perfrct length for 6th gens to use as a parking guide, iu just have them on the floor an drun over them, get kinda close, throw it i neutral and it centers itself without being like on the tires, we got fam over right now so id have to move a lot of cars to get the plywood out and junk
elmstreet
Mar 26, 2016 05:15 PM
Francis N
Honda Civic (2001 - 2005)
Oct 17, 2015 09:55 AM
mcgradiator
Aug 21, 2008 01:44 PM
mondo375
Jun 16, 2007 10:51 AM
jesseb01x
Honda S2000
May 26, 2007 11:33 AM
