aftermarket rear pads - grinding noise?
Old Jan 28, 2007 | 04:02 PM
an2ny888's Avatar
Default aftermarket rear pads - grinding noise?
i just installed a set of rigid (jdm pads i got for free) of my refaced rear rotors, and i'm hearing a sort of grinding noise when the brakes are warmed up. just want to know if this is normal when you're using aftermarket rear pads. fyi i also heard some squealing before when i was using spoon rear pads
Old Jan 28, 2007 | 07:33 PM
pyitrboy's Avatar
Default Re: aftermarket rear pads - grinding noise? (an2ny888)
aftermarket probably using more metal in the pad rather than organic making it squeel more often.
Old Jan 29, 2007 | 01:31 AM
an2ny888's Avatar
Default Re: aftermarket rear pads - grinding noise? (pyitrboy)
yeah i've heard squealing pads before. this is different, it sounds like its grinding
Old Jan 29, 2007 | 03:43 AM
non-VTEC's Avatar
you should not hear any grinding....some light squeeling depending on the pad compounds maybe but deffinatly not grinding.
take the rear pads out and check to see if something is touching the rotor.
Old Jan 29, 2007 | 07:12 AM
an2ny888's Avatar
Default Re: aftermarket rear pads - grinding noise? (non-VTEC)
i'm sure nothing was installed incorrectly, just checked it out. the grinding usually starts when the brakes get warmed up.
SimplyTron
Apr 24, 2007 07:56 PM
Flux
Jun 8, 2005 03:47 PM
Jowee
Dec 29, 2002 11:52 AM
BringIT
Aug 30, 2002 04:17 PM
95gsr
Jun 6, 2002 07:30 AM
