E.S. Motor mount inserts
I'm having trouble locating the rear motor mount in my teg.
Which is the easiest way to access it? Above or below the car, and driver or passenger side of throttle body? The closest thing I have found to a picture I have of the rear mount is underneath the car on the driverside. The HAZONE how to said there were three 14mm bolts that held the bracket on. The place I'm looking at has three 19mm bolts. Am I in the wrong place or what? I also read where someone accessed it from the top side on the passenger side of the TB, but I couldn't see the mount from that angle. Any suggestions would be appreciated.
-Nick
-Nick
The rear mount is right where the tranny meets the motor. It is below and behind the starter. You have to get it from underneath although I believe 1 bolt comes through from the pass. side so you will need to hit that one from up top. The mount is 3 large 17mm bolts and it is somewhat "L" shaped.
that thing is a pain to get to luckly i installed it when i did my swap so it was a piece of cake
but yea it is located on the firewall where the tranny meets the engine
Civichatch972
Dec 8, 2002 11:42 AM
