code 36??? and 10
i have 2 problems.. 1.. i changed my IAT sensor and it still throws out cel code 10...2.. i get code 36 ...( 3 long flashess 6 quick flashes)but i cant find code 36 on this website.http://www.c-speedracing.com/faq/05.php
can someone pleaseee tell me wat else could b wrong with the iat sensor..brand new wire harness and brand new iat sensor.. 95 delsol b16 in my 96 civic ex.. thanks alot honda tech..
yeah 10 is the air intake temp sensor....
well hondaswap.com has a reference section for 88+ civic error codes, and i didnt see a code 36..it went from 31 to 41..pretty much skipped all the 30's....cause i dont believe there is any...check it out i guess
The only thing I can think of is when someone put on your wire harness it got pinched and messed up the IAT wiring.
To see if the IAT is working fine just blow a hair dryer at it and hoop up a ohm meter up to the sensor, If resistance drops as temp increases its fine.
If that's good its your wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra »</TD></TR><TR><TD CLASS="quote">i have 2 problems.. 1.. i changed my IAT sensor and it still throws out cel code 10...2.. i get code 36 ...( 3 long flashess 6 quick flashes)but i cant find code 36 on this website.http://www.c-speedracing.com/faq/05.php
can someone pleaseee tell me wat else could b wrong with the iat sensor..brand new wire harness and brand new iat sensor.. 95 delsol b16 in my 96 civic ex.. thanks alot honda tech..</TD></TR></TABLE>
From the ECU thread at the top of the forum....
36: traction control found on JDM ecu's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra »</TD></TR><TR><TD CLASS="quote">soo0o0 anyone know how i can fix my traction control cel.. code 36...and yes it is a jdm ecu..p30...and thanks for all the help guys!!
i dont think you have traction control, so need to worry about it.
</TD></TR></TABLE>i dont think you have traction control, so need to worry about it.
jonathan13
Apr 20, 2009 06:21 AM
silentblackhat
May 1, 2005 04:41 PM
