CRX leaks under dash, on to floor when it rains.
Old Jan 28, 2007 | 02:34 PM
90crxdxb16's Avatar
Default CRX leaks under dash, on to floor when it rains.
hey i have a crx when it rains or gets wet water leaks through to the inside underdash/kick panel area i was wondeirng if anyone had this problem and knew how to fix this worried i do not want this to affect my ecu. thnaks in advance..
Old Jan 28, 2007 | 02:36 PM
dr_latino999's Avatar
Default Re: CRX leaks under dash, on to floor when it rains. (90crxdxb16)
On your passenger side or your driver's side? You mentioned your ECU so I'm leaning towards passenger but I don't know.
Old Jan 28, 2007 | 02:44 PM
90crxdxb16's Avatar
Default Re: CRX leaks under dash, on to floor when it rains. (dr_latino999)
passenger, and driver side slightly i found a few threads im leaning towards the windsheild seal im going to have to inspect it more i geuss to be sure..
Old Jan 28, 2007 | 04:02 PM
1 Fly SI's Avatar
Mine was leaking through the fresh air vent.
Old Jan 28, 2007 | 04:11 PM
90crxdxb16's Avatar
Default Re: CRX leaks under dash, on to floor when it rains. (1 Fly SI)
hmm good to know where exactly is that located? iw ant to check numer ous things as im not driving the car currently
Old Jan 28, 2007 | 04:25 PM
needashell1234now's Avatar
mine leaked ONCE when it was storming under the steering wheel by my knees. its cuz the wether strips and the other protecion they use gets old. ima replace all those wether strips and plastic trim around the windows and doors to keep water but mainly cuz the car will look brand new along with a paint job.
Old Jan 28, 2007 | 05:59 PM
1 Fly SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 &raquo;</TD></TR><TR><TD CLASS="quote">hmm good to know where exactly is that located? iw ant to check numer ous things as im not driving the car currently
Take off the wipers and the cowl under them. There is a fresh air vent on the drivers side. It is held down with two snap things. Pull them out and get the fresh air duck out. I cleaned mine real good and siliconed it back on.
Old Jan 28, 2007 | 07:35 PM
DeepInIt's Avatar
lol
kentk808
Jul 14, 2020 02:16 PM
cmc600rr
May 27, 2010 05:29 PM
blu3g
Oct 7, 2008 09:02 PM
SPOONfed-Rex
12
Jan 8, 2008 12:44 PM
synergy10
Oct 28, 2004 06:55 AM
