fuel pressure regulator
Old May 16, 2002 | 10:08 PM
erniecars's Avatar
Default fuel pressure regulator
How am I supposed to have the vaccum lines on this hooked up? I have a b16a1 in my 90 integra and my old motor had the vacuum line going from the intake manifold to the fuel pressure regulator solenoid and then to the fuel pressure regulator. Ive seen newer b16s with the vacuum line going from the intake manifold straight to the fuel pressure regulator. Which do i do? I know if i do it wrong it wastes fuel.
Old May 17, 2002 | 12:35 AM
kinesistech's Avatar
Default Re: fuel pressure regulator (erniecars)
Your supposed to have it connected directly to the intake manifold, nothing in between.
Old May 17, 2002 | 07:28 AM
TGUNNER's Avatar
Default Re: fuel pressure regulator (kinesistech)
how about on a 2000gsr.. i think my vacum lines are messed up.. the line i have going to to fpr is connected to a splitter which contains other vaccum liens, located under the intake manifod.. is this correct???
[Modified by TGUNNER, 4:29 PM 5/17/2002]
Old May 17, 2002 | 09:11 AM
TGUNNER's Avatar
Default Re: fuel pressure regulator (Teken)
damn it.. than i got i wrong... can you specify where the line comes out of of the manifold on a 2000 gsr... thanks for the help!!
Old May 17, 2002 | 09:18 AM
erniecars's Avatar
Default Re: fuel pressure regulator (TGUNNER)
According to the manuals I have, you need the solenoid between the intake manifold and the regulator on a b18a.
sliver666
Dec 18, 2008 12:07 PM
chadmasterc
Feb 28, 2006 07:29 PM
civiclxb16a
13
Mar 24, 2005 02:57 PM
integra-modder
Nov 13, 2003 08:09 PM
