engine temp sensor
Old May 16, 2002 | 10:05 PM
erniecars's Avatar
Default engine temp sensor
My stock temp gauge in my DA goes up all the way passed the red line as soon as i start the car. Anyone know what might cause this? I already replaced the temp sensor on the head and I tried a differenct cluster and it did the same thing. It only does this when the key is in the on possition.
Old May 17, 2002 | 04:25 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: engine temp sensor (erniecars)
wire not connected or a break in the circuit somewhere
Old May 17, 2002 | 05:13 AM
rainforest's Avatar
Default Re: engine temp sensor (Mista Bone)
just do a continuity test on the car and relax.
Old May 17, 2002 | 08:17 AM
Chiovnidca's Avatar
If the sensor wire is shorted to ground, they will do that. I've seen a couple pinched between the transmission and engine block after haveing the trans out.
Old May 17, 2002 | 09:19 AM
erniecars's Avatar
Default Re: engine temp sensor (Chiovnidca)
I dont think thats it. It moves up really slow. if it was shorted it would shoot up all the way right away but its so slow it seems like its working but it just goes up all the way
Old May 17, 2002 | 01:46 PM
Chiovnidca's Avatar
What does it do with the key in the on possition, engine not running?
Old May 20, 2002 | 11:29 AM
erniecars's Avatar
Default Re: engine temp sensor (Teken)
when the engine is cold as in not been running for more than 24 hours, the needle still goes up all the way so i would assume its faulty wiring and not an actual cooling problem. But i got out my multitester and checked everything and i cant find a problem so im stumped!
Old May 20, 2002 | 12:18 PM
Perfectionist's Avatar
The dash temp gauge reading is controled by it's own sending unit. In other words, not the ECT sensor typically found below the distributor. I'm not sure of where your gauge sensor is located, but I would bet that either yours has gone bad (very low resistance) or the wire leading to it has shorted to ground. I don't have the wiring diagram, but I believe you should have 12 volts going into the gauge, and then the sending unit decreases resistance as it heats up. The increased current through the gauge causes the needle to reflect a relative temperature reading.
Old May 20, 2002 | 12:52 PM
erniecars's Avatar
Default Re: engine temp sensor (Perfectionist)
that is correct. it is a single pole sensor right next to the ect. i replaced it with a new one and it didnt help.
710dabber
Nov 5, 2015 12:36 PM
707Honda
Jul 13, 2014 05:15 PM
BlackShingo
May 20, 2010 07:36 AM
Dilly
Jan 18, 2006 10:05 PM
HamiltonRex
Oct 6, 2004 01:32 PM
