coolant froze???
Old Jan 28, 2007 | 10:42 AM
JJ's civic's Avatar
Default coolant froze???
i've been having prob with my engine over heating. i flush my lines brand new themastat now i just took the water pump off to find that all the coolant in my lines, rad, and in the pump are frozen like a slushi frozen.
Old Jan 28, 2007 | 10:44 AM
crxnj's Avatar
Default Re: coolant froze??? (JJ's civic)
wrong anti-freeze/water mixture
Old Jan 28, 2007 | 10:45 AM
JJ's civic's Avatar
Default Re: coolant froze??? (mr.speaker)
i used 60/50 because its been -10 below
Old Jan 28, 2007 | 10:49 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">i used 60/50 because its been -10 below</TD></TR></TABLE>
sounds like you just added it ..but the mixture that was in there originally probably had to much water.
Old Jan 28, 2007 | 10:52 AM
JJ's civic's Avatar
no i had none so i replaced it all.
Old Jan 28, 2007 | 10:57 AM
crxnj's Avatar
well did you ever have this problem before? is this why you flushed the system and refilled it with new coolant? if so it may be the water pump,,that frozen **** will kill the water pump blades.and obviously cause overheating...I dont have any other idea .
Old Jan 28, 2007 | 11:23 AM
JJ's civic's Avatar
yea i did a little research. it's ok to have slush in the coolant on cold cold days. so i installed the water pump and i'm going to finish and then start the car pray for the best.
turbo-crx
May 14, 2008 07:04 PM
WhiteOnRice
11
Nov 30, 2007 12:59 PM
2SlowDC
Oct 1, 2005 08:32 PM
twenty
Aug 24, 2005 07:37 AM
raene
Mar 1, 2003 05:06 PM
