is taking off the belt and pulley ok?
Old Jan 28, 2007 | 10:32 AM
porter's Avatar
I'm a Jackass
Default is taking off the belt and pulley ok?
wanna remove the power steering from my car (5th gen) is taking off the belt and pulley ok? does it do the same thing w/o losing all the weight from taking it completely off?
Old Jan 28, 2007 | 11:01 AM
THC07's Avatar
Default Re: is taking off the belt and pulley ok? (UTI)
why?
taking off your PS will not make your butt dyno any faster.
just take off the belt, if it looks old then just cut if off. then later when you decide that you want your PS back, all ya gotta do is put a belt on. and you will want it back soon.
if you dont and your sure then search for it, there is a thread that tells you how to make your PS rack and pinion a manual one, draining the fluid and makeing a breather for it.
Old Jan 28, 2007 | 11:06 AM
esedulerp5tenin's Avatar
Default Re: is taking off the belt and pulley ok? (THC07)
apparently its easier to drive with PS completely removed as opposed to just taking the belt off.
i wouldn't know, cuz i only have my belt off, and i LOVEEEE itt
and there's no need to take the pulley off, only the belt.
Old Jan 28, 2007 | 11:12 AM
porter's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">why?
if you dont and your sure then search for it, there is a thread that tells you how to make your PS rack and pinion a manual one, draining the fluid and makeing a breather for it.</TD></TR></TABLE>
im not taking it off for HP gains, im taking it off so i can have a better feel and control of the car especially under heavy tq steer
now knowing my reason for wanting to take it off, will taking the belt off do what i want?
Old Jan 28, 2007 | 11:21 AM
porter's Avatar
I'm a Jackass
also can anything be damage/affected from taking the belt off besides the p/s not working?
Old Jan 28, 2007 | 11:30 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothre...86242
Old Jan 28, 2007 | 12:27 PM
porter's Avatar
I'm a Jackass
Default Re: is taking off the belt and pulley ok? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothre...86242</TD></TR></TABLE>
so whats the diff between looping it and taking the belt off? with the looping system does it just keep fluid flowing into the rack so it wont be damnaged? does looping it make it feel the same as just having the belt off?
Old Jan 28, 2007 | 01:05 PM
98vtec's Avatar
moderator emeritus
put it this way. When you are trying to turn the wheel with the belt off, what are you really trying to do? basically you are trying to push fluid through a pump that is not spinning/pumping thus making it hard to turn the wheel.
by looping the lines, you are essentially bypassing the pump and not having to push fluid through an inoperable pump.
Old Jan 28, 2007 | 03:57 PM
porter's Avatar
I'm a Jackass
Old Jan 29, 2007 | 05:56 AM
porter's Avatar
I'm a Jackass
Default Re: is taking off the belt and pulley ok? (F)
anybody else have any expierence with this?
Old Jan 29, 2007 | 04:20 PM
BlownH23a
Guest
Posts: n/a
if disabling the powersteering was a good idea, why would honda and 99.7% of all other car companies keep putting such a dumb thing as power steering into their cars in the first place. Even rally racers use power steering...just leave it on so u dont under steer into me one day trying to autocross on the street.
Old Jan 29, 2007 | 06:08 PM
98vtec's Avatar
moderator emeritus
Default Re: (BlownH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">if disabling the powersteering was a good idea, why would honda and 99.7% of all other car companies keep putting such a dumb thing as power steering into their cars in the first place. Even rally racers use power steering...just leave it on so u dont under steer into me one day trying to autocross on the street.</TD></TR></TABLE>
because power steering is a comfort item. 99.7% of people with cars will want PS.
Old Jan 29, 2007 | 09:41 PM
BlownH23a
Guest
Posts: n/a
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">because power steering is a comfort item. 99.7% of people with cars will want PS.</TD></TR></TABLE>
why do rally racers use it? last time i checked it was for control and reduction of fatigue during a long course
Old Jan 29, 2007 | 09:48 PM
Hawkze_2.3's Avatar
why do rally racers use it? last time i checked it was for control and reduction of fatigue during a long course</TD></TR></TABLE>
Some use it, some don't...unless you're trying to say that 100% of all racers use it....which they don't. It's just personal preference, man.
Old Jan 31, 2007 | 09:30 AM
porter's Avatar
I'm a Jackass
Default Re: (Hawkze_2.3)
Old Jan 31, 2007 | 10:44 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">...just leave it on so u dont under steer into me one day trying to autocross on the street.</TD></TR></TABLE>
lol, seriously
Old Jan 31, 2007 | 05:53 PM
mattmw88's Avatar
Default Re: (THC07)
On a dyno, back to back runs, I removed my p/s belt and I gained 5 WHP. Thats good enough for me.
Old Jan 31, 2007 | 06:45 PM
577HondaPrelude's Avatar
Default Re: (mattmw88)
I took mine out several years ago (looped the lines on the rack). It's only bad when the car is going real slow, like in a parking lot. However, if you plan to ever sell your car I would keep it in.
Most road racers that I know have it removed, but there are a few out there that like it and don't take it out. The ABS system is also like that, some like it in, and some removed it to save the weight.
Old Feb 8, 2007 | 09:43 PM
DFW's Avatar
DFW
Default Re: (577HondaPrelude)
Is it safe?
Old Feb 8, 2007 | 10:21 PM
E-Money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F &raquo;</TD></TR><TR><TD CLASS="quote">im not taking it off for HP gains, im taking it off so i can have a better feel and control of the car especially under heavy tq steer</TD></TR></TABLE>
IIRC, your gonna want PS for the "heavy torque steer"
qhiggy
Jun 11, 2015 04:00 PM
shadydb7
Nov 21, 2007 01:44 PM
porter
29
Jan 31, 2007 09:31 AM
95TEG
Aug 27, 2005 08:55 PM
Scharged00GsR
Jul 12, 2004 05:58 AM
