bad clutch cable = squeeking clutch pedal ???
Old Jan 27, 2007 | 11:13 PM
redDAinteg's Avatar
Default bad clutch cable = squeeking clutch pedal ???
I have a 92 teg and my clutch pedal has been squeeking for almost a year now its a driving me absolutely f'ing crazy!!! Also it doesn't feel as smooth as it used to. It feels rough and squeeky as hell!!! I can't take it anymore!!
All I can think of is either the spring where the pedal is or the clutch cable. Please help me out DA guys! I know for sure im not the only one with this problem.
Old Jan 27, 2007 | 11:31 PM
da_33's Avatar
i think its the spring? do u ever try replacing the spring? its only a spring and cant cost for than a couple dollars
Old Jan 27, 2007 | 11:35 PM
redDAinteg's Avatar
Default Re: (da_33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_33 &raquo;</TD></TR><TR><TD CLASS="quote">i think its the spring? do u ever try replacing the spring? its only a spring and cant cost for than a couple dollars</TD></TR></TABLE>
I haven't tried replacing the spring, but I have sprayed it with wd40 and it didn't do squat.
Old Jan 28, 2007 | 04:07 AM
RaceMyGhost's Avatar
Default Re: (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">
I haven't tried replacing the spring, but I have sprayed it with wd40 and it didn't do squat. </TD></TR></TABLE>
wd40 is for girls.... put some grease on that b*tch and see if that works out for you
Old Jan 28, 2007 | 08:34 AM
redDAinteg's Avatar
Default Re: (RaceMyGhost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">
wd40 is for girls.... put some grease on that b*tch and see if that works out for you </TD></TR></TABLE>
will do, i'll keep updated.
Old Jan 29, 2007 | 03:23 PM
redDAinteg's Avatar
UPDATE:
i just changed the clutch cable and it cured everything! The clutch feels solid!!!
xxpaulcpxx
Feb 2, 2011 11:44 AM
Ghost Eg
Transmission & Drivetrain
Dec 18, 2010 07:21 AM
devious
Jul 24, 2010 07:11 PM
lude1888
Apr 23, 2006 06:39 PM
Paste
Aug 30, 2002 07:57 AM
