Toda Spec D Cams anyone running these? Dyno charts? Setup?
Well reason why Im asking is because I picked up a set and plan on using them on my Ls-V setup. Anyone have any dyno chart's or setup's with these cams? If so please post them up looking for info for these cams.
I used to run Toda D's in my Civic:
The motor was 85mmx87.2mm. Stock ITR intake manifold,70mm throttle body, Hytech 2 liter big tube header, full exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixi sLik ixi »</TD></TR><TR><TD CLASS="quote">was this on pump gas 93?</TD></TR></TABLE>
Tuned on 76 Cool Blue 100.
ok but I noticed ur compression was 13:5, mine will be at 12:1 you think I will still make pretty good power? Will be using a B18b block, bored and honed to 81.5, using RS Machine ITR pistons, RMF header, and a GSR head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Those cams will be a bit much for your setup, honestly.</TD></TR></TABLE>
I fully agree. At least have a 2.0L. You won't make power throwing on such aggressive cams on a mild build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">I fully agree. At least have a 2.0L. You won't make power throwing on such aggressive cams on a mild build.</TD></TR></TABLE>
hmm well I have a 2L block sitting in the garage which I was trying to sell, hmm well I guest imma have to run stock GSR cams until I grab a more mild cam for this setup.
vtec94civic
Dec 13, 2003 06:51 PM
