190 whp LS graphs inside!!
Just got done dynoing my buddys car at King motorsports, He works there and does all of their tuning and fab work. He built it and here are the results.
Engine specs:
81.25 mm bore
jdm type r pistons
stock rods
arp bolts
ported head
.5 mm oversized valves
12.1:1 compression
b16 intake manifold 99 SI
64 mm tb
CROWER 62404 cams
CROWER springs and retainers
DC 4-2-1 2" collector
HONDATA S300
stock injectors
walbro 255
68 lbs rail pressure
2.5 inch exhaust no cat
BUILT LS vs STOCK 2000 B18b with intake and exhaust
MY gf's ls-vtec vs built ls
Her ls-vtec has 12:1 compression with type r cams
Engine specs:
81.25 mm bore
jdm type r pistons
stock rods
arp bolts
ported head
12.1:1 compression
64 mm tb
CROWER 62404 cams
HONDATA S300
stock injectors
walbro 255
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87sivtec »</TD></TR><TR><TD CLASS="quote">How streetable is it?</TD></TR></TABLE>
He drives it to work everyday for the last year and 20,000 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearsEK »</TD></TR><TR><TD CLASS="quote">
What is s300 reporting your duty cycle at ?
I would say its time for new injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
It says 83% the stock ones work fine, the pump can hold up to 70 lbs of rail pressure.
</TD></TR></TABLE>It says 83% the stock ones work fine, the pump can hold up to 70 lbs of rail pressure.
It says 83% the stock ones work fine, the pump can hold up to 70 lbs of rail pressure.</TD></TR></TABLE>
I am sure they will work fine, but you are close to the point of an upgrade.
Btw, nice numbers man
Btw, nice numbers man</TD></TR></TABLE>
Thanks i will tell him,
Like i posted i was just helping on the dyno it wasn't my engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">is this LS head B16 ported? i hear thats a common thing to do, send an LS head to a CNC machine for B16 sized ports along with B16 sized valves.</TD></TR></TABLE>
.5mm oversized ls valves, intake ports were matched to intake manifold. No guide protrusion into ports.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">how can you run a b16 manifold on an ls? same bolt pattern?</TD></TR></TABLE>Its a simple modfication, close to the same bolt pattern
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">sorry i saw that, im just unfamiliar with LS valve sizes.</TD></TR></TABLE>
the valves are 28.5mm ex and 31.5mm intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Josh »</TD></TR><TR><TD CLASS="quote">Sweet numbers
I never knew you could fab a b16 IM onto an LS head. If that's the case, why didn't he go for an ITR IM?</TD></TR></TABLE>
Thats the next mod/ test
Thats the next mod/ test</TD></TR></TABLE>
Or you could run the Blox IM, the results should be comparable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Or you could run the Blox IM, the results should be comparable.</TD></TR></TABLE>
I think he has a type r manifold already for his head, he has a fitting welded to his head so the coolant doesn't go through the manifold and the manifold is cut off. and the type r manifold he has is already cut off.
damn i didnt know a ls could put down so much hp man. i was thinking about doing a ls/vtec but i dont know? nice hp and im lovin the torque figure. what car is this in and also how does that thing pull?
damn that torque curve looks like my stock h22's, only better down low
good stuff
bears, what about his setup do you think is making that huge amount of torque in the midrange vs your gf's?? is it the cams?
good stuff
