190 whp LS graphs inside!!
Just got done dynoing my buddys car at King motorsports, He works there and does all of their tuning and fab work. He built it and here are the results.
Engine specs: 81.25 mm bore jdm type r pistons stock rods arp bolts ported head .5 mm oversized valves 12.1:1 compression b16 intake manifold 99 SI 64 mm tb CROWER 62404 cams CROWER springs and retainers DC 4-2-1 2" collector HONDATA S300 stock injectors walbro 255 68 lbs rail pressure 2.5 inch exhaust no cat BUILT LS vs STOCK 2000 B18b with intake and exhaust http://www.we-todd-did-racing.com/fi...jbi/TTR_LS.jpg MY gf's ls-vtec vs built ls Her ls-vtec has 12:1 compression with type r cams http://www.we-todd-did-racing.com/fi...R_LSvsvtec.jpg |
Re: 190 whp LS graphs inside!! (bearsEK)
non-vtec coming on like a storm lately https://honda-tech.com/forums/images/smilies/emthup.gif massive tq curve for
a 1.8 https://honda-tech.com/forums/images...s/emsmileo.gif thanks for posting this https://honda-tech.com/forums/images/smilies/emthup.gif |
How streetable is it?
Re: (87sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87sivtec »</TD></TR><TR><TD CLASS="quote">How streetable is it?</TD></TR></TABLE>
He drives it to work everyday for the last year and 20,000 miles. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearsEK »</TD></TR><TR><TD CLASS="quote">
68 lbs rail pressure </TD></TR></TABLE> What is s300 reporting your duty cycle at ? I would say its time for new injectors https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: 190 whp LS graphs inside!! (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
What is s300 reporting your duty cycle at ? I would say its time for new injectors https://honda-tech.com/forums/images...s/emsmilep.gif </TD></TR></TABLE> It says 83% the stock ones work fine, the pump can hold up to 70 lbs of rail pressure. |
It says 83% the stock ones work fine, the pump can hold up to 70 lbs of rail pressure.</TD></TR></TABLE> I am sure they will work fine, but you are close to the point of an upgrade. https://honda-tech.com/forums/images...s/emsmilep.gif Btw, nice numbers man |
I am sure they will work fine, but you are close to the point of an upgrade. https://honda-tech.com/forums/images...s/emsmilep.gif Btw, nice numbers man</TD></TR></TABLE> Thanks i will tell him, Like i posted i was just helping on the dyno it wasn't my engine. https://honda-tech.com/forums/images/smilies/emthup.gif |
is this LS head B16 ported? i hear thats a common thing to do, send an LS head to a CNC machine for B16 sized ports along with B16 sized valves.
Re: 190 whp LS graphs inside!! (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">is this LS head B16 ported? i hear thats a common thing to do, send an LS head to a CNC machine for B16 sized ports along with B16 sized valves.</TD></TR></TABLE>
.5mm oversized ls valves, intake ports were matched to intake manifold. No guide protrusion into ports. |
how can you run a b16 manifold on an ls? same bolt pattern?
sorry i saw that, im just unfamiliar with LS valve sizes.
Re: 190 whp LS graphs inside!! (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">how can you run a b16 manifold on an ls? same bolt pattern?</TD></TR></TABLE>Its a simple modfication, close to the same bolt pattern
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">sorry i saw that, im just unfamiliar with LS valve sizes.</TD></TR></TABLE> the valves are 28.5mm ex and 31.5mm intake |
Loving the non-VTEC numbers https://honda-tech.com/forums/images/smilies/emthup.gif
I would love to hear more about the head! |
Re: 190 whp LS graphs inside!! (b19coupe)
those torque #s are awesome. long live the No VTEC. haha. https://honda-tech.com/forums/images/smilies/emthup.gif that motor outta scream.
Sweet numbers https://honda-tech.com/forums/images/smilies/emthup.gif
I never knew you could fab a b16 IM onto an LS head. If that's the case, why didn't he go for an ITR IM? |
Re: 190 whp LS graphs inside!! (EK Josh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Josh »</TD></TR><TR><TD CLASS="quote">Sweet numbers https://honda-tech.com/forums/images/smilies/emthup.gif
I never knew you could fab a b16 IM onto an LS head. If that's the case, why didn't he go for an ITR IM?</TD></TR></TABLE> Thats the next mod/ test |
Really nice numbers!
Re: 190 whp LS graphs inside!! (mr_hahn73)
200+ here we come https://honda-tech.com/forums/images/smilies/emthup.gif
Thats the next mod/ test</TD></TR></TABLE> Or you could run the Blox IM, the results should be comparable. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Or you could run the Blox IM, the results should be comparable.</TD></TR></TABLE> I think he has a type r manifold already for his head, he has a fitting welded to his head so the coolant doesn't go through the manifold and the manifold is cut off. and the type r manifold he has is already cut off. |
damn i didnt know a ls could put down so much hp man. i was thinking about doing a ls/vtec but i dont know? nice hp and im lovin the torque figure. what car is this in and also how does that thing pull?
Re: 190 whp LS graphs inside!! (SuperTomcat)
great comparison https://honda-tech.com/forums/images/smilies/emthup.gif
impressive
damn that torque curve looks like my stock h22's, only better down low https://honda-tech.com/forums/images...s/emsmileo.gif
good stuff https://honda-tech.com/forums/images/smilies/emthup.gif bears, what about his setup do you think is making that huge amount of torque in the midrange vs your gf's?? is it the cams? |
