change brake pads all at once? or front/rear one at a time?
Old May 16, 2002 | 08:03 PM
comptechgsr's Avatar
Default change brake pads all at once? or front/rear one at a time?
my fronts are giving in (squeeking in reverse)
how do i check my rear brake pads?
when i change my fronts, should i just change the whole set?
thanks
Old May 16, 2002 | 08:21 PM
dc24me's Avatar
Default Re: change brake pads all at once? or front/rear one at a time? (comptechgsr)
Look between the spokes at the caliper. You can usually see how much pad you have left. Front brakes do most of the braking, so the rears could be fine.
You don't necessarily have to change both ends. I need to change my rears soon.
[Modified by dc24me, 12:22 AM 5/17/2002]
Old May 17, 2002 | 04:50 AM
nsxtcjr's Avatar
New User
Default Re: change brake pads all at once? or front/rear one at a time? (dc24me)
Just change one axle at a time, when it's worn down to about 2 mm of pad material remaining.
There's no need to change rears when your front pads are worn.
jlowellintegra
Dec 23, 2010 09:46 PM
sunnyside
Sep 5, 2005 06:46 AM
comptechgsr
May 4, 2003 07:11 AM
98R-1144
Nov 1, 2002 03:50 PM
hobo79
Mar 5, 2002 08:10 PM
