Broken trans? not sure
gears goes in? but car moves..meaning life if u put it in any gear than the car will roll when u push it..when u step on the clutch it makes a scratchn noise? anyone have a clue? motor LS/Vtec..
Modified by crxsi8 at 5:29 PM 1/27/2007
sounds like youve got something thats really broken inside this transmission. How did it happen? sounds like where the shifter goes into the transmission is broken, can you feel the gear slots?
yes i can feel the gear slots..i did a 1-2nd gear shift..and it sounded like a missed? but didn't,...wierd? can it be clutch cause it only makes the noise if i step on the clutch..otherwise car idles..puts it in gear and you can push it as if it was on nuetral..
If its going into all gears, Not moving at all, then you shattered your diff teeth, I've done that double clutching in second to show off and bam, no more moving,, Get a new diff, or good time for an upgrade.
well i was told? s1, J1, Y1 has different clutch teeth than the ys1? something like that..so i used a ys1 clutch disked on a s1...and boom the clutch is gone..well ill be pulling apart the motor and seeing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">so i used a ys1 clutch disked on a s1...and boom the clutch is gone..well ill be pulling apart the motor and seeing?</TD></TR></TABLE> um problem solved
the ys1 disc had a larger center splined hole, it was probably just catching on the splines and now the splines are stripped or mangled. I hope you just broke the disc and dont need a whole new mainshaft as well
Koko4
17
Jul 17, 2013 07:03 PM
Mario.
18
Dec 16, 2004 11:21 AM
BlackOutIntegra
May 6, 2004 10:47 AM
Qwikrex
23
Apr 22, 2003 11:07 AM
