Fuel System for 650-700whp??
ive heard a lot of good, and bad things about the aeromotive a-1000. im in the market for a fuel system and i would love some feedback from some car owners in similar power situations input. the car will be driven on the street fairly often as well. de-tuned of course.
wow! im sorry but did you try seaching....
There is plenty of info on this!!!!! top competitiors use the aero a-1000 with no problems...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol »</TD></TR><TR><TD CLASS="quote">wow! im sorry but did you try seaching....
I've been looking here recently and couldn't find some of the older threads about this topic. I've been tryin to find the thread with some of the pics of sumped tanks and pump mounting location, etc... I'll be ordering everything I need as soon as I get my tax returns. Any links that any of yall know about or could post of up would be great..
-Chad-
-Chad-
The best setup is to sump the tank and run an external pump. The A1000 is a great pump, just make sure its either level or below the sump. You don't really want the pump higher then the sump. Other than that make sure you run a filter before and after the pump. And you'll probably want something like a -8 or -10 feed, and a -6 or -8 return.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 »</TD></TR><TR><TD CLASS="quote">im running one walboro intank with another inline.</TD></TR></TABLE>
what I will be doing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2K »</TD></TR><TR><TD CLASS="quote">The best setup is to sump the tank and run an external pump. The A1000 is a great pump, just make sure its either level or below the sump. You don't really want the pump higher then the sump. Other than that make sure you run a filter before and after the pump. And you'll probably want something like a -8 or -10 feed, and a -6 or -8 return.</TD></TR></TABLE>
This is what i'm gonna go with. Just wondering about how to mount the pump so that it's level/below the sump. Anybody got any pics..
-Chad-
-Chad-
i did... it seems whenever i search for something, i never find quite what im looking for. i was hoping some of the sfwd guys would chime in a bit more
is the one in line the same "in-tank" style pump? Excuse my ignorance I havent seen someone do this... Doesnt the pump require to be submerged in gasoline to cool the pump? Are you afraid of the pump overheating if not in gas or a cool environment.....
Just a thought
Just a thought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny_EJ »</TD></TR><TR><TD CLASS="quote">is the one in line the same "in-tank" style pump? Excuse my ignorance I havent seen someone do this... Doesnt the pump require to be submerged in gasoline to cool the pump? Are you afraid of the pump overheating if not in gas or a cool environment.....
Just a thought</TD></TR></TABLE>
I'm doing the same thing. It's not just an "intank" pump that's run inline. It's a different pump.
Here's a pic for reference:
I have a intank walbro 255 hp and another walbro 255 hp inline up on my fire wall all with -8an line from the top of the tank to the rail with a stock return line , and I also running a FJO injector driver with my rc 1000cc injectors , will be good for around 750 whp
What I'll have once the new motor is in:
Full-Race Sump
Dual Bosch 044
-10 AN Feed, -6 AN Return
Y-Block to primary rail w/ RC 750's, and to secondary rail w/ RC 750's
Aeromotive A1000 FPR
Should be good for quite a bit of power
Full-Race Sump
Dual Bosch 044
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">I have a intank walbro 255 hp and another walbro 255 hp inline up on my fire wall all with -8an line from the top of the tank to the rail with a stock return line , and I also running a FJO injector driver with my rc 1000cc injectors , will be good for around 750 whp
My exact set-up
</TD></TR></TABLE>My exact set-up
Not with 1000cc Injectors it wont be...
</TD></TR></TABLE>Not with 1000cc Injectors it wont be...
I'm also interested in seeing some dual bosch setups as well. My only walbro in tank is not going to feed a motor with a ported head, mazworx cams, top mount and a gt4202 lol....subscribed
the a1000 is pretty loud and kind of OD for a street car so thats why im using the intank and inline...i also heard alot about them burning out. i dont know if anyone else heard this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 »</TD></TR><TR><TD CLASS="quote">the a1000 is pretty loud ...i also heard alot about them burning out. i dont know if anyone else heard this?</TD></TR></TABLE>
I've heard of them burning out as well, which is why in my mind you can't go wrong with the Bosch 044.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">
I've heard of them burning out as well<U></U>, which is why in my mind you can't go wrong with the Bosch 044.</TD></TR></TABLE>
I've been researching this topic as much as possible here lately. It seems to be that most people who are burning up the Aeromotive pumps are not mounting them in the proper way, Level or below the sump. They are gravity fed and if they are ran dry will burn up. Correct me if I'm wrong.
I've found some good links about sump, placement on pumps, ect..
https://honda-tech.com/zerothread?id=1707093
https://honda-tech.com/zerothread?id=577865
https://honda-tech.com/zero...age=1
https://honda-tech.com/zero...age=2
Hope this helps.. I'm still up in the air on a few things. like the most effcient way to modify the gas tank for the sump.. etc.. I've got a pretty good idea. So, thanks to those who have posted on this subject.
-Chad-
-Chad-
Cyphear
Mar 1, 2007 02:56 AM
4doorH22
10
May 17, 2004 10:43 AM
