Best shocks with crx suspension
Old Jan 27, 2007 | 09:41 AM
honda_coupe's Avatar
Default Best shocks with crx suspension
iim currently looking at Ground Control Coilovers.. and now im not sure if i want Tokico Illumina Shocks, Koni Sports, or KYB sport shocks. I know these are adjustable shocks, but do i really need adjustable shocks with coilovers? Or should i find a pair of springs with aftermarket shocks?
Old Jan 27, 2007 | 10:11 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Best shocks with crx suspension (honda_coupe)
You need to figure out if you need adjustables your self we can't tell you all you'll hear is bandwagoners who own what they push or what the mob tells them.
Frankly Koni is the best shock out there if you need on car adjustables or not is up to you.
Old Jan 27, 2007 | 10:17 AM
office888's Avatar
Default Re: Best shocks with crx suspension (Max The Amazing)
Koni Yellows, hands down.
Koni's been in the business a while. They know what they're doing and they're built like a tank.
If you're going to buy performance shocks, I highly advise an adjustable set. Coilovers are great for people who want to be able to raise and lower their ride in less than 30 minutes. Adjustable shocks allow you to set your rebound/damper so you can go between "Highway Cruise" mode and "Stiffazz Track" mode. =D
Old Jan 27, 2007 | 12:13 PM
Default Re: Best shocks with crx suspension (office888)
yeah i relize, but should i get adjustable coilovers with adjustable shocks? Or get springs, with adjustable shocks?
Old Jan 27, 2007 | 12:22 PM
rewerbcrx's Avatar
that all depends on if you want to raise or lower your ride... and or if you need to change the rebound rate ie: whether you do drag, auto-x, dd, or weekend warrior...
this is all your decision
Old Jan 27, 2007 | 12:54 PM
Default Re: Best shocks with crx suspension (rewerbcrx)
well im just asking for opinions. Because i know adjustable shocks are more pricey, but im just wondering if i really need them with already adjustable coil overs? and if its worth the money, that is all. I will be dragging it, and autox it
Old Jan 27, 2007 | 01:23 PM
rewerbcrx's Avatar
then def you would want adjustable everything, basically because they are two totally different fields of racing... the adjustability gives you the option to fine tune to the type of track/ strip your on...
I do not run coilovers, my vehicle is a summer weekend warrior... i stuck with springs and adjustable shock/struts
technically if you bought anything it would have been a better buy if you bought adjustable shocks/struts over coilovers (adjustable springs) because you can still be higher in the air (stock springs) with a decent suspension setup and still run alright times in auto-x with adjustable shocks/struts.
mynameizstitch
Suspension & Brakes
Feb 17, 2009 04:24 AM
pipes
Nov 7, 2003 06:21 AM
wuggiewuggie
Jun 6, 2002 09:22 PM
SIK IN DA HED
Feb 20, 2002 09:14 PM
H22AccordEX
Dec 14, 2001 05:41 AM
