Carbon fiber - high temp resins?
Old Jan 26, 2007 | 11:28 PM
dubseven's Avatar
Default Carbon fiber - high temp resins?
What kind of resins are available? Anything to withstand 700-800C?
Old Jan 27, 2007 | 09:35 AM
MAFDARK's Avatar
Default Re: Carbon fiber - high temp resins? (dubseven)
http://www.compositemarket.com..._ID=4
Old Jan 27, 2007 | 09:40 AM
carbonall's Avatar
* B A N N E D *
good info!
Old Jan 27, 2007 | 10:01 AM
toyomatt84's Avatar
Sanji
All I saw was Ceramic Matrix resin that could handle over 2000° F. Is that all?
Also, is it heavy, as in terms of much larger weight, almost steel-like weight? Or is it just heavier than typical resin? I know these questions sound very noobish, but I'm quite interested in high-temp. resins for a future project.
Old Jan 28, 2007 | 08:11 PM
dubseven's Avatar
So where can you get that Ceramic stuff, too?
Old Jan 29, 2007 | 01:23 PM
crx12's Avatar
Default Re: (dubseven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">All I saw was Ceramic Matrix resin that could handle over 2000° F. Is that all?
Also, is it heavy, as in terms of much larger weight, almost steel-like weight? Or is it just heavier than typical resin? I know these questions sound very noobish, but I'm quite interested in high-temp. resins for a future project.</TD></TR></TABLE>
Uhh 2000F is pretty high as far as composites go. The density of the material is going to vary. Sourcing the material isn't the hardest part, the question is do you have the equipment to process any type of part correctly at these temps? I would look into that first before you go down this road. There is a reason carbon ceramic brakes,clutches cost so much.
Old Jan 29, 2007 | 01:40 PM
toyomatt84's Avatar
Sanji
Default Re: (crx12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx12 &raquo;</TD></TR><TR><TD CLASS="quote">
Uhh 2000F is pretty high as far as composites go. The density of the material is going to vary. Sourcing the material isn't the hardest part, the question is do you have the equipment to process any type of part correctly at these temps? I would look into that first before you go down this road. There is a reason carbon ceramic brakes,clutches cost so much.</TD></TR></TABLE>
Oh, I completely understand how long/tedious of a process it is to cure certain resins, in order to prevent failure. I'm just starting to look into what all products would be necessary for the style project I have in mind. It's rather atypical in design, but I have a completely controllable environment to do my testing, so as not to injure myself or anyone else. It's just going to take time/money/development to produce properly. Which is fine by me, since I love projects like this.
Old Jan 29, 2007 | 02:41 PM
crx12's Avatar
Default Re: (toyomatt84)
Oh I didn't mean, do you have an oven that hits 2000F? I am more concerned about what your mold is going to be made from. What are you trying to build? Do you have many thousands of dollars to throw at this project?
Old Jan 29, 2007 | 05:23 PM
toyomatt84's Avatar
Sanji
Default Re: (crx12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx12 &raquo;</TD></TR><TR><TD CLASS="quote">Oh I didn't mean, do you have an oven that hits 2000F? I am more concerned about what your mold is going to be made from. What are you trying to build? Do you have many thousands of dollars to throw at this project? </TD></TR></TABLE>
It's a side project I'll be starting over this summer, and continuing over the course of a few years. I'll have thousands to throw at it, that's for sure. I can get an oven that can hit 2000 F, but why would I need that? I thought the curing process was done at a much lower temperature. Once again, I know I'm newer to the product.
Old Jan 29, 2007 | 09:24 PM
crx12's Avatar
Because you said this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">All I saw was Ceramic Matrix resin that could handle over 2000° F. Is that all?</TD></TR></TABLE>
I assumed your requirement is higher than 2000f. The original poster was asking about 1300-1500 f
Old Jan 30, 2007 | 08:53 AM
toyomatt84's Avatar
Sanji
Default Re: (crx12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx12 &raquo;</TD></TR><TR><TD CLASS="quote">Because you said this:
I assumed your requirement is higher than 2000f. The original poster was asking about 1300-1500 f </TD></TR></TABLE>
I was just curious as to high they went in temperature ratings. It's not that I need higher, I was just being curious. All I need it to handle, is about 1600 F at the absolute most, so 2000 F will be more than plenty durable.
Old Jan 30, 2007 | 11:45 PM
dankeg's Avatar
sorry for not being helpful. but what would you need to have a temp rating of 1600. is it for you honda? just wondering if you dont mind sharing.
Old Jan 30, 2007 | 11:48 PM
crx12's Avatar
Well anything over 450F is sort of in the same family, expensive and not really DIY in most cases but where there's a will there's a way. 450-500F is pretty high for laminating resins. Here is a little flow chart that walks you through the process steps in a carbon ceramic part, go to page 2.
http://www.fz-juelich.de/iwv/i...c.pdf
Check out the siliconization step for the part: Stick part in a vacuum oven at 1450C
or the carbonization step: In argon atmosphere at 950C
By all means keep going and show me when you're done. I have never done anything like this but I know people that have and funding is a big deal on these types of projects.
Old Jan 31, 2007 | 12:06 AM
toyomatt84's Avatar
Sanji
Default Re: Carbon fiber - high temp resins? (dankeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankeg &raquo;</TD></TR><TR><TD CLASS="quote">sorry for not being helpful. but what would you need to have a temp rating of 1600. is it for you honda? just wondering if you dont mind sharing.</TD></TR></TABLE>
Exhaust manifolds, turbo housings, and the like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx12 &raquo;</TD></TR><TR><TD CLASS="quote">Well anything over 450F is sort of in the same family, expensive and not really DIY in most cases but where there's a will there's a way. 450-500F is pretty high for laminating resins. Here is a little flow chart that walks you through the process steps in a carbon ceramic part, go to page 2.
By all means keep going and show me when you're done. I have never done anything like this but I know people that have and funding is a big deal on these types of projects.</TD></TR></TABLE>
I appreciate it, truly. That will come in very handy for the future products.
Old Feb 3, 2007 | 01:39 PM
dubseven's Avatar
My idea was to create a carbon fiber exhaust, perhaps minus the downpipe.
turnsignalandy
Apr 15, 2007 11:09 PM
everlasting1832
Nov 18, 2005 12:13 PM
EKcivic1230
May 26, 2005 11:15 AM
RicTRD
Jan 9, 2005 06:23 PM
akaEsCo01
May 25, 2003 11:45 AM
